Latest post Fri, Jun 24 2016 7:50 PM by insch. 7 replies.
  • Thu, Jun 16 2016 7:22 PM
    • insch
    • Posts 372
    • Points 4,390
    FS700 linked media appears offline
    I have been linking to several folders of media files (from different cameras) in my current project and selectively transcoding. All generally fine on most of the footage but I am having problems with all the folders of Sony FS700 footage. Media Composer appears to link to the clips but then when I double click them I get 'media offline'. Any thoughts anyone?
    Thanks.
    Mac Pro, 3.7 GHz Quad-core, 64GB RAM, G-Tech G-RAID Studio 6TB and 10TB etc. [view my complete system specs]
  • Tue, Jun 21 2016 10:26 AM In reply to
    • Dan
    • Joined on Fri, Aug 12 2011
    • UK
    • Posts 231
    • Points 3,190
    Re: FS700 linked media appears offline
    Hi Insch, have you tried changing the plugin to the correct one in the 'files of type' drop down menu when linking? i.e. change it from autodetect (which doesn't always work well) to the specfic sony one. I'm not sure on the FS700 plugin but our Fs7 uses the XAVC/XDCAM one.
    Symphony 8.5.3 Windows 7 pro 64bit. Intel Core i7 2600k. 16GB RAM. Nvidia Quadro fx5500. [view my complete system specs]
  • Wed, Jun 22 2016 1:18 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,911
    • Points 50,005
      Moderator: MCA Mac
    Actually according to Avid, auto detect is the preferred mechansim to use for any folder based media.
    Dave S.
  • Wed, Jun 22 2016 6:08 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    DStone:
    This is my daily bread workflow with FS 700 media , never fails
    Tomas
  • Wed, Jun 22 2016 7:15 AM In reply to
    DStone:
    I believe this has only been the case for the last few versions of MC 8. Prior to that, in my experience, manually selecting the correct AMA codec was more reliable for many formats.
  • Wed, Jun 22 2016 1:05 PM In reply to
    • Dan
    • UK
    • Posts 231
    • Points 3,190
    Agreed, we have just updated all suites to the latest version, from 8.3 - hopefully autodetect does work now (haven't tested it yet) but for the Fs7 footage it didn't previously on both our ingest machines - always had to select the AMA plugin.
  • Fri, Jun 24 2016 4:28 PM In reply to
    • insch
    • Posts 372
    • Points 4,390
    Thank you everyone. Just got back to check this post. Will try manually setting plug-ins. I am using the latest version of MC.
  • Fri, Jun 24 2016 7:50 PM In reply to
    • insch
    • Posts 372
    • Points 4,390
    I found out that the Sony plug-in wasn't installed at all. It now is and all is well. Thanks.
