Latest post Thu, Jul 28 2016 9:10 PM by RalphC. 12 replies.
Page 1 of 1 (13 items)
  • Wed, Jun 15 2016 3:14 PM
    • Dan
    • Joined on Fri, Aug 12 2011
    • UK
    • Posts 231
    • Points 3,190
    Using MC 8, 8.1 or 8.2 with an 8.5.3 dongle
    Hi, this might be an easy answer, but I couldn't find this specific question on the FAQs.
    We are updating some PCs and were going to use a spare Avid dongle (for which we have a support plan) to use 8.5.3 on an recently updated PC. The processor is a bit old though (HP XW8400 - dual Xeons) so apparently 8.5.3 won't work, we might have to use 8.2 or lower.
    My question is: Can I use a dongle updated to 8.5.3 for this? Or is there a way to get a dongle updater for older versions of MC on our account? The dongle is not yet updated - I think it's still on MC 5ish, so should I go ahead with updating it?
    Thanks in advance
    Symphony 8.5.3 Windows 7 pro 64bit. Intel Core i7 2600k. 16GB RAM. Nvidia Quadro fx5500. [view my complete system specs]
  • Wed, Jun 15 2016 4:09 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,906
    • Points 32,105
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Using MC 8, 8.1 or 8.2 with an 8.5.3 dongle
    Hello Dan,
    Dan:
    Thanks in advance
    The short answer is yes MC 8 Dongle license is compatible with all MC8x version and also backward compatible to lower version FAQ here.
    Regards,
    Ralph
    MacBook Pro 15 2018 Intel Core i7 2.6GHz Mac 10.15.7 Intel UHD 630. [view my complete system specs]
  • Thu, Jun 16 2016 12:14 PM In reply to
    • Dan
    • UK
    • Posts 231
    • Points 3,190
    Hi Ralph,
    Thanks, good to know. There is a bit of a problem still - when I try to update the dongle in app manager it says it isn't compatible with this version. I assume this is because the dongle is going straight from an older version of Avid, which it has been running for a while (around MC3 I think) straight up to 8.5.
    I should probably post another question for this, but as you replied thought you might know the answer to this too!
    Cheers
  • Thu, Jun 16 2016 2:51 PM In reply to
    • RalphC
    • Posts 2,906
    • Points 32,105
      Avid Employee
    Dan:
    Hi Ralph,
    Cheers
    Did you obtain an .avd updater file? Use the most updated AppMan.
    Regards,
    Ralph
  • Fri, Jun 17 2016 9:50 AM In reply to
    • Dan
    • UK
    • Posts 231
    • Points 3,190
    Hi Ralph,
    Yes, have an .avd file, but the app manager is the one that installed with the Avid version (8.2). However it won't sync so I can update it (it's just hanging) and the usual procedure of signing out, closing it and signing back in won't work as there is no sign-out button. I've also followed these instructions to get it to reset:
    On Windows please:
         • Quit App Manager via right+click on tray icon, selecting Quit
         • Open Task Manager, Processes and also stop the "AppManagerHelper" process
         • Go to: C:\ProgramData\Avid\AppManager
         • Delete the "Cache" and "Db" folders
    ....but to no avail, after restarting the PC and the app man, it still just goes straight to 'syncing' and hangs for ever.
    Aargh, etc.
  • Fri, Jun 17 2016 2:26 PM In reply to
    • RalphC
    • Posts 2,906
    • Points 32,105
      Avid Employee
    Dan:
    IIRC that is a bug in the previous AppMan, here is the link for the latest AppMan.
    Regards,
    Ralph
  • Fri, Jun 17 2016 2:29 PM In reply to
    • Dan
    • UK
    • Posts 231
    • Points 3,190
    Aha, thanks Ralph, I thought you had to use to AppMan to download the latest AppMan, so was caught in a logical loop.
  • Fri, Jun 17 2016 3:24 PM In reply to
    • RalphC
    • Posts 2,906
    • Points 32,105
      Avid Employee
    Dan:
     Actually, your thought is right, you have the option to update the AppMan via the AppMan, it's the sync process that got in the way.
    Ralph
  • Wed, Jun 22 2016 1:13 PM In reply to
    • Dan
    • UK
    • Posts 231
    • Points 3,190
    Hi Ralph, thanks for the help. Unfortunately, using the latest AppMan doesn't work either, when updating it states 'no dongle compatible with this update file found'.
    I think it just must be that the dongle is quite old (it's the purple 'Rainbow Super-Pro' type) and has missed quite a few updates so it can't leap straight to the latest updater. I might start a ticket and see if Avid can supply an interrim updater, or firmware flash or something.
    I suppose we could do the online activation as a last resort, but the dongles are more useful for us so hopefully it can be sorted.
    Cheers for the advice anyway.
    Dan
  • Wed, Jun 22 2016 3:03 PM In reply to
    • RalphC
    • Posts 2,906
    • Points 32,105
      Avid Employee
    Hello Dan,
      pm me the case number just in case, I will do a follow-up
    Ralph
  • Mon, Jul 4 2016 10:58 AM In reply to
    • Dan
    • UK
    • Posts 231
    • Points 3,190
    Hi Ralph,
    Sorry for not replying, I didn't get the email alert - anyway, Avid customer service sorted it out it 5 mins by sending a new dongle updater file, so all is good now.
  • Fri, Jul 8 2016 6:10 PM In reply to
    • RalphC
    • Posts 2,906
    • Points 32,105
      Avid Employee
    Dan:
    Hi Ralph,
    Yes
  • Thu, Jul 28 2016 9:10 PM In reply to
    • RalphC
    • Posts 2,906
    • Points 32,105
      Avid Employee
    Email alert is now fixed a big thanks to Marianna Yes
