Latest post Sun, Dec 4 2022 12:54 AM by mohammad kittaneh. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Feb 26 2016 7:30 PM
    subtitle: how?
    hello need to put some subtitle in a little interview. what is the best way to do that?
    CPU I7 2600k 3.4ghz Ram 32gb Ssd 256gb GPU Nvidia GTX760 Win 10 Avid First [view my complete system specs]
  • Fri, Feb 26 2016 7:59 PM In reply to
    Re: subtitle: how?
    The Subcap effect is what you want. The Media Composer help explains how to use it in detail.
    Media Composer 2022.12.2 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Sat, Feb 27 2016 7:10 AM In reply to
    • M-Edit
    • Joined on Thu, Jan 29 2009
    • Posts 226
    • Points 2,630
    Re: subtitle: how?
    Hi, have a a look at this thread.
    http://community.avid.com/forums/t/137916.aspx
    It's from the MC Mac forum but it still applies to PC use and
    might give some additional info that the help file doesn't.
    And a tutorial:
    AVX SubCap Effect - Avid Media Composer Tutorial
    https://www.youtube.com/watch?v=_cwKUm4FheQ
    ...and you can find more tutorials on YouTube.
    Cheers.
    //Mike-E
  • Wed, Mar 2 2016 2:18 PM In reply to
    Re: subtitle: how?
    i have given a look and try to use..2 main questions
    is there a way to give an exact position to the text, for example, centre..looks like i should set it manually
    is there a way to make the lines of text longer.default is quite short
  • Wed, Mar 2 2016 7:56 PM In reply to
    Re: subtitle: how?
    stefanocps:
    The anchor position determines where the subtitle appears. The default, for some stupid reason, is the upper left corner of the screen, so you'll have to change it manually.
    stefanocps:
    Box width is the parameter that determines how much text of a particular font size will fit on a line.
  • Sun, Dec 4 2022 12:54 AM In reply to
    Re: subtitle: how?
    hi
    https://www.nikse.dk/subtitleedit
    save it avid caption.txt
    adding the 'Subcap' effect to a video track
    import .txt
