Worked for my as a workaround on MC 8.6.1 with MOJO DX. All glory to your head, zonik, you saved my sanity.
Did anyone have a good solution for this apart from restarting or disabling / enabling the driver?
Disabling windows fastboot can resolve this issue
https://www.google.com/search?source=hp&q=disable+fastboot+windows+10&oq=disable+fastboot&gs_l=psy-ab.3.0.0l4.6094474.6097368.0.6098440.16.15.0.0.0.0.184.1547.0j12.12.0....0...1.1.64.psy-ab..4.12.1546...0i131k1.0.xE1is0p2C_4
Many thanks.
I had to disable fast boot in the BIOS AND in windows - that did the trick.
I also had this issue after upgrading to windows 10.
The solution Yoruba describes about changing the power options has solved this issue for me on all my workstations that I upgraded to windows 10.
Julian
thanks for the info and Yoruba thanks for the tip.
marianna
Where is this power options?
