Latest post Tue, Dec 1 2015 7:08 PM by fgarcia. 2 replies.
  • Mon, Nov 30 2015 5:24 PM
    • fgarcia
    • Joined on Mon, Nov 30 2015
    • Posts 2
    • Points 20
    **HELP Digital Cut Device Output
    Hello Peeps-
    I am trying to output from Media Composer 7.0.4.4 MacPro OS 10.8.5 to the HDCam HDW-1800. The output out of the Mac is Kona 3.
    In the Digital Cut window, Avid does recognize the deck for control but the device output only shows as IEEE 1394 DVCPro. The DVCPro isn't even on or connected.
    I am at a loss as to figure out how to get the Output device to change to the correct deck. I've updated drivers, software, changed user settings, projects, checked all connections from the workstation to the deck and router.
    I am able to get FCP7 to output to the HDCam deck just fine.
    Thanks in advance for any help or ideas provided.
    Fred
  • Mon, Nov 30 2015 5:55 PM In reply to
    Re: **HELP Digital Cut Device Output
    The Special > Device menu isn't relevant in this situation...you should just be able to output.
    Can you verify that the deck is getting the Avid signal via HD-SDI when you put the deck into E/E and play something on MC?
  • Tue, Dec 1 2015 7:08 PM In reply to
    • fgarcia
    • Posts 2
    • Points 20
    Kevin-  Thank you for your response.  It turns out (and I have never used this before) to be that the button "HW/SW Switch" was disabled.  Once I enabled this button.  The Digital Cut tool was able to see the HDCam deck.
    Go figure!
