Latest post Tue, Nov 24 2015 4:42 PM by Eric V. 2 replies.
  • Mon, Nov 23 2015 10:34 PM
    • Eric V
    • Joined on Tue, Jun 23 2015
    • Posts 20
    • Points 220
    DNX_GetInfoFromCompressedFrame returns DNX_INCOMPATIBLE_PARAM_VERSION
    I tried using the function DNX_GetInfoFromCompressedFrame to parse a DNx compressed frame and extract the compression id but it always fails with error -1010. This frame is from MXF and QuickTime DNxHR files exported from MediaComposer 8.5b2. My code was previously fetching the compression id directly at byte offset 40 (0x28) and that was working fine.
    Is this a known bug? Otherwise what does this error mean?
    Eric
    I'm using DNxHR SDK version 2.2.1.19.
  • Tue, Nov 24 2015 8:38 AM In reply to
    • OleksiiK
    • Joined on Mon, Dec 23 2013
    • Posts 25
    • Points 270
    • Avid Developer Moderator
    Re: DNX_GetInfoFromCompressedFrame returns DNX_INCOMPATIBLE_PARAM_VERSION
    Do you set a proper compressed param version by setting
    compressedParams->structSize = sizeof(DNX_CompressedParams_t) ?
  • Tue, Nov 24 2015 4:42 PM In reply to
    • Eric V
    • Posts 20
    • Points 220
    Thanks, that was it. :-)
    I would recommend adding a note in the header file in the comments for DNX_GetInfoFromCompressedFrame.
    Best regards,
    Eric
