Latest post Mon, Jan 11 2016 10:13 AM by digitalheaven2. 18 replies.
Page 1 of 2 (19 items) 1 2 Next >
  • Mon, Aug 24 2015 9:54 PM
    Alpha channel not available from DNxHD files
    Hi
    We have a QTKit-based app which a customer has contacted us to report a problem with DNxHD. Basically the alpha channel isn't being output correctly and is full frame white, regardless of the content of the file. I've replicated this myself with the 2.6.0 codec release using any variant of DNxHD.
    The app works perfectly with ProRes 4444 or Animation codec files that have alpha, so I'm not sure what is going on here. Any ideas?
    thanks
    Martin
  • Tue, Aug 25 2015 9:52 AM In reply to
    • OleksiiK
    • Joined on Mon, Dec 23 2013
    • Posts 25
    • Points 270
    • Avid Developer Moderator
    Re: Alpha channel not available from DNxHD files
    Are you using DNxHD SDK or QuickTime DNxHD Codec Component?
  • Tue, Aug 25 2015 10:07 AM In reply to
    This is with the QT component.
    Martin
  • Tue, Aug 25 2015 10:33 AM In reply to
    • OleksiiK
    • Posts 25
    • Points 270
    Are you setting right Alpha compression parameters in Compression settings window?
  • Tue, Aug 25 2015 10:40 AM In reply to
    This is playback issue not encoding. My test files were made in AE and definitely have alpha channel.
    Interestingly the same problem happens when files are imported into FCPX, but they are fine in FCP7.
    Martin
  • Tue, Aug 25 2015 12:54 PM In reply to
    • OleksiiK
    • Posts 25
    • Points 270
    digitalheaven2:
    That is strange. I am sorry, but I could not help you anymore with this issue.
  • Tue, Aug 25 2015 2:58 PM In reply to
    So there are no known issues with this? If not, how do I submit a bug report?
    thanks
    Martin
  • Mon, Sep 7 2015 9:36 AM In reply to
  • Tue, Sep 8 2015 12:07 PM In reply to
    • OleksiiK
    • Posts 25
    • Points 270
    This is not a known issue. Could you please provide more information in order to create a bug description.
    Which resolution is selected in Standard Video Compression Settings? Which alpha? How the movie file was created? What OS(es) are you using? Is it possible to provide 1 frame long movie with the issue?
    Oleksii.
  • Thu, Sep 10 2015 6:53 AM In reply to
    Hi Oleksii
    I have some more information on this. As I said before this is not a problem with the encoded file, it is the decoding within QT. I've since discovered it only happens in a 32 bit app build and in a 64 bit app the alpha channel is decoded correctly.
    It can be replicated by using the CALayerEssentials sample code from Apple, and updating the -(void)setupQTMovieLayer method to use a DNxHD file with alpha. The target architecture will also need to be changed to "32-bit Intel (i386)".
    Martin
  • Wed, Oct 21 2015 7:49 AM In reply to
    Any update on this issue please?
  • Wed, Oct 21 2015 3:23 PM In reply to
    • Posts 11,593
    • Points 256,090
    digitalheaven2:
    Hello, apologize for the inconvenience. Please allow me to escalate this on the right department and provide you an update.
  • Wed, Oct 21 2015 3:24 PM In reply to
    • Posts 11,593
    • Points 256,090
    digitalheaven2:
    I will also ask to get some assistance as soon as possible.
  • Wed, Oct 21 2015 6:19 PM In reply to
    • Posts 11,593
    • Points 256,090
    digitalheaven2:
    Hello, can you please provide a sample file (you can send it on my email) so we can test it from our end.
  • Tue, Oct 27 2015 11:59 AM In reply to
    I've sent sample apps and media file but link will expire in 2 days, so please download ASAP.
    thanks
    Martin
