Latest post Fri, Feb 27 2015 7:25 PM by Jackrabbit416. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Feb 12 2015 10:03 PM
    Can Not Export Single Field Quicktimes in MC 8.3
    Upgraded to 8.3 and now i can't export a quicktime single field. I tried multi codecs, projects, and on 2 different 8.3 systems. The Quickitme always comes out with fields in them.
    Also tried the same sequence on a 7.x system and it expoerted just fine single field.
    System specs
    Avid Media COmposer 8.3
    Imac 27inch late 2012
    3.4 GHZ Intel i7 (quad)
    16gig ram
    Nvidia Geforce GTX 680MX 2gig
    OS X 10.8.5
    Thanks!
  • Fri, Feb 13 2015 1:58 AM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,569
    • Points 64,855
      Moderator: MCA Mac
    Re: Can Not Export Single Field Quicktimes in MC 8.3
    What's the format of your project and how are you setting single field output?
  • Fri, Feb 13 2015 2:48 AM In reply to
    NTSC 30i
    Clicking the Single field button on the front page of the export tool. We have tried both the same export settign from 7.x and made a new one in 8 (and on 2 different user systems)
  • Fri, Feb 13 2015 4:43 AM In reply to
    • hbrock
    • Posts 5,569
    • Points 64,855
      Moderator: MCA Mac
    What is the source codec and what codec are you exporting?  I'll try to reproduce it at my end (and anybody else who wants to join in is welcome as well).
  • Fri, Feb 13 2015 7:16 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    Jackrabbit416:
    NTSC 30i
    Just curious - why would you want to export single field? You lose half your vertical resolution doing that. I'm assuming its for some kind of preview purpose..
    John
  • Fri, Feb 13 2015 5:58 PM In reply to
    Footage is 20:1 NTSC, we've exported both h264 and ProRez both came out with fields.
    Single field is for approval postings on the web, we don't want the interlacing lines in the video playback for clients.
    We have also uninstalled and reinstalled and same issue. Again works fine on a 7.0.4 system.
  • Fri, Feb 27 2015 7:25 PM In reply to
    Update. Problem is still there
    Installed 8.3 on a 3rd system. Started a new project with new media, which was AMA'd in and then trancoded to 14:1 Standared def. Then opened media in a 30i project, exported and still getting fields in my single field quicktimes settings. Any update on this?
    Also tested it on a 4th system running Os X 10.10 still same issue.
