Latest post Tue, Feb 3 2015 1:37 AM by videojon. 7 replies.
  • Tue, Jan 20 2015 9:12 PM
    • videojon
    • Posts 63
    • Points 800
    Audio issues
    Over the last couple weeks, there has been a growing problem with my audio output. Lately, especially after sitting idle overnight or even several minutes, Avid will intermittently only play out my left channel of audio. It then finally snaps out of it after a few seconds or minutes - often during the playout. Another symptom being that three times now, I've played a sequence and the audio repeats a 1 second or so portion during playout causing everything to play out of sync.
    Early on I thought it was my audio mixer hardware before other symptoms began.
    Does this sound like an Avid issue? AJA IO Express issue? or perhaps a drive (SAN) issue?
    Thanks in advance.
    Jonathan
    Setup #1 - MC 8.2 with Symphony HP Z800; Windows 7, 12 gigs ram, NVIDIA Quadro FX 4800, AJA AJKONALHI Setup #2 - Media Composer 8.2; AJA IO Express; Windows... [view my complete system specs]
  • Tue, Jan 27 2015 10:46 AM In reply to
    • digibeetle
    • Joined on Fri, Oct 14 2005
    • The Netherlands
    • Posts 155
    • Points 1,940
    Re: Audio issues
    Hi Jonathan,
    Have you been able to get any further with your audio problem? I'm also having a customer with similar problems; after the system has been idle lots of times the audio playback will become muffled and very low volume. This can only be solved by restarting Media Composer. This system is also using a Io Express and MC 8.2 so they are somewhat similar (other specs: Z440, 32GB RAM, Win 8.1 x64).
  • Wed, Jan 28 2015 2:56 PM In reply to
    • videojon
    • Posts 63
    • Points 800
    Re: Audio issues
    Interesting. No suggestions yet. The only thing I haven't done yet is upgrade to 8.3 from 8.2.
  • Wed, Jan 28 2015 3:41 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: Audio issues
    Matrox works brilliant here on Pc so that might point towards Aja , maybe try different drivers
    Tomas
  • Wed, Jan 28 2015 7:02 PM In reply to
    • digibeetle
    • The Netherlands
    • Posts 155
    • Points 1,940
    Re: Audio issues
    I have tried to upgrade from 8.2 to 8.3 and also installed the latest AJA drivers (new unified driver release) but seems not to have helped... Also double checked everything was setup per Avid's Z440 config guide. Disabled Win8 fast start. But it still is happening my customer is telling me :-(  (of course it doesn't happen when i'm onsite)
  • Wed, Jan 28 2015 9:03 PM In reply to
    Re: Audio issues
    FWIW you used to get something like this happen with the Digi IO settings on a Mac. Deleteing the preferences and letting Avid rebuild them would solve it.
    It MAY be worth going through and rebuilding all the settings. See Randall's post here
  • Wed, Jan 28 2015 10:59 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,436
    • Points 55,100
    Re: Audio issues
    I assume the audio VU meters indicate volume? or are they flat?
    Using MC 22.12. Win 22H2  Avid FX6.4, Vegas Pro 20/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Tue, Feb 3 2015 1:37 AM In reply to
    • videojon
    • Posts 63
    • Points 800
    Re: Audio issues
    I'll play around with the user profiles and look at other suggestions.
    Yep, VU meters look just fine throughout.
    Jonathan
