Latest post Mon, Jan 12 2015 6:39 PM by smrpix. 3 replies.
  • Sun, Jan 11 2015 11:48 PM
    • Indyreel
    • Joined on Thu, Jul 1 2010
    • Posts 70
    • Points 1,210
    Need help exporting for Vhx
    I'm trying to export my film for VOD streaming on VHX. They gave me their Remmended specs, which are:  H264, 13000 bit rate . I tried that but when the video plays you can see some type of pixilating in the background, like when there is a fade in or if there is a dim background. Ex. A fade in to a sunrise shows multiple bands or halos of colors spreading out around the sun, until the fade in ends.
    Does anyone know what export settings I need to use to correct this (using MC5) for a file that will stream from the VHX site?
  • Mon, Jan 12 2015 7:04 AM In reply to
    Re: Need help exporting for Vhx
    Don't use Avid for the H264 export.
    Mixdown to a suitable codec (DNX120 maybe) then export a same as source QT. Then use an external encoder like Squeeze to make the H264
  • Mon, Jan 12 2015 6:21 PM In reply to
    • Indyreel
    • Posts 70
    • Points 1,210
    Will DNxHD175X work or is it too big for streaming. I usually export out at this setting and it comes out clear but its a large file, then I use Handbrake to knock it down and it still looks good. I just don't know whether this will work for streaming. I'm going through HVX for my streaming provider.
  • Mon, Jan 12 2015 6:39 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,489
    • Points 18,560
    Handbrake should be able to provide a stream that complies with the specs you've listed.
    (You're just doing a variation on the method Pat described above and substituting Handbrake for squeeze.)
