Latest post Wed, Dec 12 2018 5:37 PM by carcharias. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Nov 25 2014 2:59 PM
    relink offline media
    Hi
    1- I have an offline media  on my timeline which it is not in any bin so I have that just on timeline
    How can I relink it?
    2- I transcoded an AMA link and then I moved it to different place
    when I used  "Relink " to reconnect it to the transcoded file it can not found and relink it anymore.
    May I ask you to help me pls?
    Protools 11 HD, HD Native Card, D-Command, Omni, Sync IO Symphony 6 / Media composer 8 Mac Pro, Macbook Pro 13" Retina, Mac OS 10.10 [view my complete system specs]
  • Tue, Nov 25 2014 4:07 PM In reply to
    Re: relink offline media
    Alireza Vasefi:
    If you use the hamburger (fast) menu in your sequence bin, you can choose "Set Bin Display" and then select "Show Reference Clips."  This will populate your bin with all of the clips used in your sequences in that bin.  Then at least you can "Find Bin" to the clip that is offline and try to relink that.
    I'm confused on this one...What exactly are you trying to relink?  It sounds like you have an AMA-linked clip and you're trying to relink it to a transcoded file?  Why would you try to do that?
  • Fri, Nov 28 2014 6:45 PM In reply to
    Kevin Klimek:
    Alireza Vasefi:
    Hi
    Thanks for your help
    I used some ama link and I maid multicam and group but I have to send my time line to the other FCP editor.
    But I couldnt export my timeline to fcp if I have AMA link on my timeline.  After export to fcp AMA links will be blank space on FCP time line
    So I have to relink them  to transcode file.
    Actualy I have basic problem with relink on MC. Why I can not relink with select actual file and I have to use auto relink with search? when I try  to relink them directly to transcode file Mc dosent accept that.
    I found a way to solve my problem. with "toggle Source/Record" I found my source and then I relinked them .
    But still I have my problem. Why for relink we have to select AMA folder and how "Relink" works?
  • Tue, Apr 7 2015 6:27 PM In reply to
    Sorry, this is a bit different but I have some Media offline but it is because my external hard drive change system letter (from J to S) so does anyone know how I can remap it so it can be the same system letter again in avid not windows. I know how to do it in windows and I don't want to do it there because another drive might have it already. I tried relink but it didn't work. any tips?
    Avid Media Composer 8.3 W/Nitris DX, HP Workstation z820, Windows 7 64bit, 16gb Ram, Intel(R) Xeon(R) CPU E5-2640 0 @ 2.50GHz 2.50GHz (2 processors) [view my complete system specs]
  • Wed, Apr 8 2015 2:17 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    GalvanAle:
    Why are you asking a question about drive letters in the Mac forum? Anyway just AMA your source clips again and they will automatically relink to the master clips (most times). Avid does not control drive letters the system does.
    John
  • Wed, Apr 8 2015 2:39 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    Alireza Vasefi:
    Avid manages and tracks it's media differently to other NLE's. It has pros and cons. If you have transcoded your clips they should no longer be AMA linked but should reside in the Avid MediaFiles directory. This has the advantage of working no matter where the drive is mounted. You don't have to search for media at all. Whats more Avid doesn't lose renders when you change monitoring etc. It is a lot more robust and less prone to errors than say FCP but not as easy to understand.
    John
  • Wed, Dec 12 2018 5:37 PM In reply to
    • carcharias
    • Joined on Mon, Apr 7 2014
    • Los Angeles, CA
    • Posts 17
    • Points 245
    Kevin Klimek:
    Alireza Vasefi:
    This worked for me like a charm. No other replies I've searched for over the last many months had worked, so thank you.Yes
    MacBook Pro running 10.14.6 (Mojave) 2.8GHz Intel Core i7 16GB 1600 MHz DDR3 AMD Radeon R9 M370X [view my complete system specs]
