Latest post Mon, Jun 20 2022 5:31 PM by www.drastic.tv. 3 replies.
  • Fri, Jul 18 2014 12:06 AM
    708 Caption Support in AMT V2.7
    Hello,
    I hve been having some issues getting 708 (608 with compatibility bytes) onto the Avid data track.  When using the AMT V2.7 and creating XDCAM in OP-Atom, it seems that only 608 captions are making it to the data track.
    I have heard rumour that this was an issue and was fixed in V2.8 but i cannot see anything in the release notes for 2.8 or 2.9.  Please can someone confirm if this is correct?
    Filed under: , ,
  • Wed, Jul 23 2014 12:09 AM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 262
    • Points 3,110
    • Avid Developer Moderator
      Avid Employee
    Re: 708 Caption Support in AMT V2.7
    Hi Simon,
    AMT supports reading and writing of data tracks containing SMPTE ST 436 ANC Elements. AMT does not enforce or check ANC Element payload validity. Whether or not the payload of an ANC Element buffers passed to AMT is valid  needs to be taken care of in the application that uses AMT. There have been no changes to AMT’s ANC data support implementation or documentation since the 2.6.0 release. There are no known issues.
    Vadym
  • Wed, Jul 23 2014 12:52 PM In reply to
    Vadym,
    Ok, understood.  Thanks for the response.
    Simon
  • Mon, Jun 20 2022 5:31 PM In reply to
    Sorry to re-awaken this thread, but I am trying to write 436 via AMT 3 and I cannot get it to create a working MXF file.   This is AMT 5.2.2.10098 using the data track as described in the sample MADs.  I have tried with and without SMPTE ANC ID + Ber, and tried fixed 256 bytes with 0 padding and the actual CC size.  Here is the MAD entry for the track
    <mpmad:DataTrack>
    <mpmad:EditRate>
    <mpct:Numerator>30000</mpct:Numerator>
    <mpct:Denominator>1001</mpct:Denominator>
    </mpmad:EditRate>
    <mpmad:SampleRate>
    </mpmad:SampleRate>
    <mpmad:FramePreCharge>
    <mpct:Numerator>0</mpct:Numerator>
    <mpct:Denominator>1</mpct:Denominator>
    </mpmad:FramePreCharge>
    <mpmad:BoundedEditUnitSize>256</mpmad:BoundedEditUnitSize>
    <mpmad:DataEssenceEncodingFamily>ANC</mpmad:DataEssenceEncodingFamily>
    </mpmad:DataTrack>
    and a sample of the valid cc data I am trying to send
    0x00 0x01 // Number of packets
    0x00 0x09 // Line
    0x01 // Interlaced
    0x04 //  8 bit luma
    0x00 0x4C // Size 1
    0x00 0x00 0x00 0x4C // Size 2
    0x00 0x00 0x00 0x01
    // ANC Packet 61:01 with padding
    0x61 0x01 0x49 0x96 0x69 0x49 0x4F 0x43 0x00 0x00 0x72 0xF4
    0xFC 0x80 0x80 0xFD 0x80 0x80 0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA
    0x00 0x00 0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA 0x00
    0x00 0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA 0x00 0x00
    0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA 0x00 0x00 0xFA 0x00 0x00 0x74 0x00 0x00 0xBF
    0x06 0x0E 0x2B 0x34 0x01 0x01 0x01 0x01 0x03 0x01 0x02 0x10 0x01 0x00 0x00 0x00
    0x83 0x00 0x00 0x7C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    The 'D' mxf shows up with the V and A ones, the AAF is created at the end, but the D mxf is invalid (header only , no track) and the elements inside are generally two bytes of 0 for each entry. Any help would be greatly appreciated. Thanks, James
