Hi All,
I recently encountered a problem that may be familiar to some of you. Our situation: we had an image sequence (PNG) rendered from After Effects. The correct playback rate of the image sequence is 23.976 FPS. However, we wanted to import this image sequence into a 1080i/59.94 Avid project. Our hope was that when we imported the 24P sequence within MC, it would automatically apply 3:2 pulldown, just as it does with a 24P Quicktime file (when importing it into a 59.94i project). Of course, when you do this, MC assumes the image sequence should be played at the project framerate (29.97 FPS in this case), so it plays back much too fast.
Our solution was to apply a Timewarp effect to the clip after we cut it into a sequence. The following settings produced the correct playback speed and pulldown cadence:
Type: Both Fields
Source: Progressive
Output: Film With 2:3 Pulldown
Speed: 80.00%
I'm sure a lot of you already know this little trick, but hopefully this post will help someone out in the future.
Cheers,
-Jason Stoughton
Jason StoughtonRTPO Creative Director/Towne GroupDefense Media Activityyoutube.com/rtpoproduction
Or just import the file into a 24p project, open the 59.94i project, open the bin from the 24p project and splice the shot into your timeline. Motion adapter will be applied automatically.
