I have Symphony 6.5.2 and i need export to Quick Time XDCAM EX 1080i6 (35mb/s).
and i have already install
Mac AMA AVCHD v1.2
Mac Panasonic P2 AMA v2.6
PDZK-MA2 v2.33
MXF- plugin setup
AvidCodecsLE
Do I need another codec to make it work to export XDCAM EX?
tengo el symphony 6.5.2 y necesito exportar a formato Quick Time XDCAM EX 1080i60 (35mb/s).
tengo instalado
Necesito otro codec para exportar a XDCAM EX?
First, you shouldn't have the LE version of the Avid Codecs installed. MC/SN will automatically install the PE version.
A QT Reference file can be exported using XDCAM Media. Neither the Avid nor Sony software includes a QT Codec to decode the reference file.
If you're on a Mac you can get the codec by installing one of the Apple Pro Video Apps.
On Windows and Mac the Calibrated Software XD Decode will do this.
Do you have to export a QT file? MC/SN can export an OP1a MXF file using the XDCAM Optical, XAVC and HDCAM SR codecs.
You could export to MXF and then rewrap to mov using ffmbc
