Sylvain, I know that you've told me numerous times that there will be no further development in the DS's 3D DVE area. And it's because of that I was quite surprised, when I a while back, found that the naming of some of the menuitems in the 3D DVE has changed? More specifically for the menues that appear when you right-click in the Viewer-window after choosing "Rotate" or "Light".
So I just wonder why someone at Avid goes to the trouble of changing these, when there are real mishalfs that needs fixing first, like the issue with the "Camera (K)" parameters that only can be viewed in Direct Mode" but never are transferred to the output?Or was it a big demand for these name changes?
And regarding the "Camera (K)" parameter, as I also said numrous times before. I'll never believe the explanation that states that this parameter couldn't make it through the 32- to 64-bit conversion. The four others did. like "Camera Pan (I)", "Dolly (P)", "Tumble (O)" and "Roll (L)". So why not "Camera (K)"? My firm belief is that someone had a bad hair day, and put the wrong letter in a parameter name somewhere in the code, so that the the parameters in different areas of the code aren't identified/linked correctly. A single uppercase letter in place of a lowercase, or vice versa, is all it takes.
And I can understand that someone now feel the urge to comment on to why I keep dwelling on this antique subject, because there are more important issues that needs adressing, like the DS's inability to handle a lot of the newer fiile formats natively.
Well, fine, there are, and I would have settled with the notion that there will be "no more development", but then I noticed this name changing. What for? And that makes me upset, because they've actually taken away a feature from the 3D DVE that we used a lot. To get in close and get great and/or weird perspectives.Grrrowl...//Mike-E
Anyway, below are the changes I've noticied:
Normal 0 21 false false false SV X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normal tabell"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;} table.MsoTableGrid {mso-style-name:Tabellrutnät; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-priority:59; mso-style-unhide:no; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;}
v.7.6
v.11.0.2
Rotate (D)
Reset Rotation
RotateResetRotation
Reset Anchor Point
RotateResetCenter
Light (Y)
Add Light
LightCreate
Delete Lights
LightDelete
Enable Lights
LightEnable
Disable Lights
LightDisable
Light Type
LightType
Infinite
LightInfinite
Local
LightLocal
Spot
LightSpot
Well... what did I expect really...?//Mike-E
I was out of the office since Monday so I did not see your message, sorry if you thought that I was ignoring you.
I was not aware of any such changes in the 3D DVE, honestly. I'll have a chat with engineering and try to understand why this happened.
But I also want to inform you that I will be offline for the next three weeks as I am taking much needed vacations. So this will explain my silence and absence from this community during this period.
Sylvain LabrossePrincipal Expert | Services and Customer SuccessAvid3510 St-Laurent BoulevardMontréal, QC H2X 2V2Canadasylvain.labrosse@avid.com Create cases online now at csportal.avid.com It's fast, easy and effective!We're Avid. Learn more at www.avid.com
Fair enough, Sylvain.So maybe I´ll hear from you later on this year.//Mike-E
Many employees on vacation so I am not getting answers yet... Ok, I'll log this information and I'll get back to it when I come back from my own time off.
Cheers!
We definitely hope to hear from you after your holidays, Sylvain....
John
So, Sylvain, with the new DS EOL info thrown in our face, could you PLEASE, PLEASE, PLEASE se to that the two issues in the 3D DVE will be fixed while you still have some coders left in the building?Unless, Avid will leave the 3D-DVE EOL'ed in worse condition than it was in v7.6.Pretty, please...//Mike-E
