Latest post Wed, Aug 7 2013 6:21 AM by M-Edit. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Jul 29 2013 1:54 PM
    • M-Edit
    • Joined on Thu, Jan 29 2009
    • Posts 226
    • Points 2,630
    The "3D DVE"... (again)...
    Sylvain, I know that you've told me numerous times that there will be no further
    development in the DS's 3D DVE area. And it's because of that I was quite surprised,
    when I a while back, found that the naming of some of the menuitems in the 3D DVE
    has changed? More specifically for the menues that appear when you right-click in the
    Viewer-window after choosing "Rotate" or "Light".
    So I just wonder why someone at Avid goes to the trouble of changing these, when there
    are real mishalfs that needs fixing first, like the issue with the "Camera (K)" parameters
    that only can be viewed in Direct Mode" but never are transferred to the output?
    Or was it a big demand for these name changes?
    And regarding the "Camera (K)" parameter, as I also said numrous times before.
    I'll never believe the explanation that states that this parameter couldn't make it
    through the 32- to 64-bit conversion. The four others did. like "Camera Pan (I)", "Dolly (P)",
    "Tumble (O)" and "Roll (L)". So why not "Camera (K)"?
    My firm belief is that someone had a bad hair day, and put the wrong letter in a parameter
    name somewhere in the code, so that the the parameters in different areas of the code
    aren't identified/linked correctly. A single uppercase letter in place of a lowercase, or vice versa,
    is all it takes.
    And I can understand that someone now feel the urge to comment on to why I keep
    dwelling on this antique subject, because there are more important issues that needs
    adressing, like the DS's inability to handle a lot of the newer fiile formats natively.
    Well, fine, there are, and I would have settled with the notion that there will be "no
    more development", but then I noticed this name changing. What for? And that makes
    me upset, because they've actually taken away a feature from the 3D DVE that we used
    a lot. To get in close and get great and/or weird perspectives.
    Grrrowl...
    //Mike-E
    Anyway, below are the changes I've noticied:
    Normal 0 21 false false false SV X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normal tabell"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;} table.MsoTableGrid {mso-style-name:Tabellrutnät; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-priority:59; mso-style-unhide:no; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-fareast-language:EN-US;}
    v.7.6
    v.11.0.2
    Rotate (D)
    Rotate (D)
    Reset Rotation
    RotateResetRotation
    Reset Anchor Point
    RotateResetCenter
    Light (Y)
    Light (Y)
    Add Light
    LightCreate
    Delete Lights
    LightDelete
    Enable Lights
    LightEnable
    Disable Lights
    LightDisable
    Light Type
    LightType
                   Infinite
                   LightInfinite
                   Local
                   LightLocal
                   Spot
                   LightSpot
  • Wed, Jul 31 2013 10:19 AM In reply to
    • M-Edit
    • Posts 226
    • Points 2,630
    Re: The "3D DVE"... (again)...
    Well... what did I expect really...?
    //Mike-E
  • Thu, Aug 1 2013 7:35 PM In reply to
    • slabross
    • Montreal, Quebec, Canada
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    I was out of the office since Monday so I did not see your message, sorry if you thought that I was ignoring you.
    I was not aware of any such changes in the 3D DVE, honestly. I'll have a chat with engineering and try to understand why this happened.
    But I also want to inform you that I will be offline for the next three weeks as I am taking much needed vacations. So this will explain my silence and absence from this community during this period.
    Sylvain Labrosse
    Principal Expert | Services and Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    Create cases online now at  csportal.avid.com
    It's fast, easy and effective!
    We're Avid.  Learn more at www.avid.com
  • Thu, Aug 1 2013 8:37 PM In reply to
    • M-Edit
    • Posts 226
    • Points 2,630
    Fair enough, Sylvain.
    So maybe I´ll hear from you later on this year.
    //Mike-E
  • Fri, Aug 2 2013 6:52 PM In reply to
    • slabross
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    Many employees on vacation so I am not getting answers yet...  Ok, I'll log this information and I'll get back to it when I come back from my own time off.
    Cheers!
    Sylvain Labrosse
    Avid
    Canada
  • Mon, Aug 5 2013 7:54 PM In reply to
    • jpheiser
    • Birmingham, Alabama, USA
    • Posts 35
    • Points 370
    We definitely hope to hear from you after your holidays, Sylvain....
    John
    DSv11 - MC8.4.2 - HP Z800 - AJA - Sonnet Fusion 8TB [view my complete system specs]
  • Wed, Aug 7 2013 6:21 AM In reply to
    • M-Edit
    • Posts 226
    • Points 2,630
    So, Sylvain, with the new DS EOL info thrown in our face, could you
    PLEASE, PLEASE, PLEASE se to that the two issues in the 3D DVE will
    be fixed while you still have some coders left in the building?
    Unless, Avid will leave the 3D-DVE EOL'ed in worse condition than it
    was in v7.6.
    Pretty, please...
    //Mike-E
