Latest post Mon, Jul 29 2013 7:37 AM by Moses.M. 2 replies.
  • Mon, Jul 29 2013 7:02 AM
    XDCAM file size increases after AMA transcode?
    I have a 32GB SxS card from a Sony EX1 (XDCAM EX.)   The card is nearly full--31 gigs of almost 2 hours of footage.   I linked by AMA and then transcoded the footage to DNxHD 145.   The resulting Avid MediaFiles are 119 gigs...almost 4 times the size of the original footage.
    Why are the transcoded Avid MediaFiles so much larger than the original (long GOP) files on the SxS card?   Since DNxHD is a relatively efficient codec, I would have thought it would have been the other way around???
    MC 2018.12.3 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system... [view my complete system specs]
  • Mon, Jul 29 2013 7:21 AM In reply to
    Re: XDCAM file size increases after AMA transcode?
    As a test, I exported the files from the SxS card using the Sony Browser.  (Export MXF for NLE).   The resulting file exports are the same size as the files on the card--31 gigs.
  • Mon, Jul 29 2013 7:37 AM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Austria
    • Posts 651
    • Points 8,200
    Terry:
    I guess your clips on the card use the XDCAM codec with 35MBit/sec, other variants use 50MBit/sec (HD 422).
    Your AMA transcoded files use DNxHD with 145Mbit/sec.
    145 : 35 =  4,14
    But: did you expect anything else??
    You could consolidate your SxS card - the size would be the same because the codec would be the same - like your attempt with the Sony Browser.
    HP xw8400 - 6GB RAM | W7 64 bit | MC 5.5.2 | Adrenaline with DNxcel Sony Vaio SB1Z1 - 6GB Ram | W7 64 bit | Blackmagic Design Ultra Studio SDI [view my complete system specs]
