Latest post Wed, Sep 16 2015 10:24 PM by DStone. 4 replies.
  • Mon, Jul 8 2013 5:29 PM
    • giovanii
    • Joined on Mon, Jul 8 2013
    • Posts 1
    • Points 25
    Marquee - Timeline duration
    Hello everyone,
    I have an animation on Marquee that has 5 sec. of duration, so is my timeline.
    Now see, I want to extend  my timeline to 10 sec. without extend my animation duration, but when I go at File> Duration... it extend my animation to 10 sec.
    Anyone knows how to help me out?
    Thanks for your attention.
  • Mon, Jul 8 2013 6:34 PM In reply to
    Re: Marquee - Timeline duration
    I usually save the last frame of the animation as a separate title and cut it into the timeline at the end of the animation to the duration I want
  • Wed, Sep 16 2015 8:45 PM In reply to
    • F J L Inc
    • Joined on Wed, Oct 17 2012
    • Posts 20
    • Points 350
    In Marquee:
    Go to 'Marquee' in the file menu
    select preferences
    sselect 'current title'
    change animation duration
    When you save it and import it into Avid, it will import as a 5 second clip.
    Use your yellow trim roller bar to extend it to the length you intended it to be in Marquee.
  • Wed, Sep 16 2015 9:41 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,911
    • Points 50,005
      Moderator: MCA Mac
    F J L Inc:
    In Marquee:
    select preferences
    Simple. Why didn't anyone answer this before. Sometimes this forum is so lame!
    Basic questions like this continue to show up in Google queries, yet now simple answers.
    Which, if you try it out, extends the entire animation out and moves the keyframes so that they maintain their relative positions. In other words, if your timeline was originally 5 seconds long and you have a keyframe at the 2 second mark, changing the timeline to 10 seconds moves the keyframe to the 4 second mark.
    Which is not what the user wanted. He wants to extend the animation without moving the keyframes.
    F J L Inc:
    How totally lame
    No comment.
    Dave S.
  • Wed, Sep 16 2015 10:24 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,911
    • Points 50,005
      Moderator: MCA Mac
    F J L Inc:
    Only static (non-animated titles) are always import as 5 second clips. Animated titles are rendered out as a TIFF clip at the length of the duration (as set in preferences->current title->animation duration). And you can't extend the length of a clip past the end of the clip.
    The method mentioned by Andrew is the easiest way to extend the clip. The other way is to set the animation duration before you set your keyframes so that the animation ends where you want it and then stays static for the remainder.
    Dave S.
