Latest post Wed, Jul 17 2013 7:38 AM by berga. 12 replies.
Page 1 of 1 (13 items)
  • Tue, Jul 2 2013 1:40 PM
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,665
    • Points 19,990
    MC7, P2 audio and DMF no link
    I have a problem, my or Avids?, with P2 files and DMF.
    The process works well for video files, but no audio file is copy or transcoded. I got this messages: "AMA Link operation failed (in "link AMA" phase)."
    I also got problems wih File/AMa link. I got error. "Unable to linki to any clips at D:\P2".
    What does I wrong?
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows 7 Pro Swedish, MC7 with Symphony option, Blackmagic... [view my complete system specs]
  • Tue, Jul 2 2013 2:15 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,780
    Re: MC7, P2 audio and DMF no link
    This is happening, a lot, to me, as well. DMF seems to be a bit buggy on this first release.
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Tue, Jul 2 2013 4:56 PM In reply to
    • berga
    • Posts 1,665
    • Points 19,990
    After several hours of transcoding the video, I got this message:
    "Cannot Import composition: C:\Users\Public\Documents\Avid Dynamic Media Folders\tmp\4ee0b139-9d93-480d-ab97-8f4885bbaa45\000000-374938a0376205ef-008045822d15-7633.aaf : FileCompositionToken cannot be converted to in-memory representation (in "transcode in-progress" phase)."
    Someone who knows what it is?
  • Fri, Jul 5 2013 5:55 AM In reply to
    • berga
    • Posts 1,665
    • Points 19,990
    Bump. Any suggestion?
  • Wed, Jul 10 2013 7:17 PM In reply to
    • berga
    • Posts 1,665
    • Points 19,990
    Bumpili bump.
    Is this something which must be solved with payed support?
  • Tue, Jul 16 2013 8:20 AM In reply to
    • berga
    • Posts 1,665
    • Points 19,990
    Bump
  • Tue, Jul 16 2013 8:24 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Anders, do you have a small zipped card uploaded somewhere, otherwise, please pm me to send me a stick to test on.
    Tomas
  • Tue, Jul 16 2013 8:25 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,950
    • Points 70,365
    Did You install the latest P2 AMA plugin or You're still running off the MC 6.5's plugin? QT and nVidia versions?
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Tue, Jul 16 2013 11:19 AM In reply to
    • berga
    • Posts 1,665
    • Points 19,990
    I have installed P2 v.3 now and I am able to link and transcode. But I have not been able to start DMF yet. I will try to comfirm is v3 works.
  • Tue, Jul 16 2013 1:47 PM In reply to
    • berga
    • Posts 1,665
    • Points 19,990
    Nvida: Included wihith MC7.
    QT: 7.7.1
    I think one clue for makeing AMA-link to work is not using autodetect AMA. Set to P2-folder.
    I am now able to link and transcode by manual AMA-link. I got error for audio, "AMA Link operation failed (in "link AMA" phase). But audio is on the transcoded clips. Maybe they are pointed to the original audio files.
  • Tue, Jul 16 2013 5:59 PM In reply to
    • berga
    • Posts 1,665
    • Points 19,990
    Mjolnarn: Thankt You for Your offer. Maybe I got time tomorror to make a Zipfile and upload it.
    My conclusion now is this.
    1. If You use P2 folder with DMF, the import will not start.
    2. If You try to set a specific profile for manual import, It will not work.
    My work around just now this.
    Do a manual import and move the clips to the apropiate bin.
    At least, We can still work with P2 media.
  • Tue, Jul 16 2013 7:34 PM In reply to
    • RajK
    • Joined on Mon, Sep 8 2008
    • Posts 20
    • Points 265
    • Avid EAC Moderator
      Avid Employee
    Avid Engineering is tracking bug 180199 for the issue with DMF not working if the watch folder is set directly on the P2 folder within the card reader slot directory structure.
    Raj
  • Wed, Jul 17 2013 7:38 AM In reply to
    • berga
    • Posts 1,665
    • Points 19,990
    Thank You.
    Do You know if there is a bug with autodiscver AMA, P2 and audio. Setting profile to autodiscover make DFM miss the audio part.
