Latest post Fri, Jun 28 2013 4:32 PM by camoscato. 7 replies.
  • Thu, Jun 27 2013 1:09 PM
    Upres final sequence from import
    Hello all,
    I may be confused on my workflow, but I am looking to upres a finished sequence. I imported my clips with file > import instead of AMA. The files were imported as DNxHD 115 MXF. I would like to upres, but most of the info I am finding on these forums up upresing from AMA links. How can I do it when I import the files directly?
    My footage is from a Canon 5d mk II, .h264 .mov files.
    Also, would it save space on my hard drive if I had just linked to AMA in the first place?
    Thank you for your time,
    Patrick
    Filed under: , ,
  • Thu, Jun 27 2013 1:21 PM In reply to
    Re: Upres final sequence from import
    Hi Patrick,
    patskehill:
    Batch Import is the function you want.  Select the file(s) you imported at DNxHD 115, and select Batch Import (Clip menu I think).  The Batch Import dialog box will ask if you want offline files or all files, and you want all files.  Select whatever resolution you want to use, and Media Composer will re-import the files at the higher resolution, linking them up to the sequences you've used them in.
    patskehill:
    Yes, because AMA only links to the files, it doesn't create new media like importing does.
    Hope that helps.
    ciao,
    Carl
    Media Composer 2022.10 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Thu, Jun 27 2013 1:25 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,474
    • Points 18,320
    Unlike the AMA>Transcode workflow, the import>re-import workflow means you have to re-import any clips used in their totality.  This costs not only disk space but time.
  • Fri, Jun 28 2013 1:01 PM In reply to
    Thanks for the help.
    But now I wonder for future projects. Is switching to an AMA link for importing files preferable? Most of my projects tend to be longer (an hour+) and all of the footage comes from the 5d.
    Also am I able to sync sound with AMA clips with the same method I used for imported files?
    Patrick
  • Fri, Jun 28 2013 1:20 PM In reply to
    Hi Patrick,
    patskehill:
    Generally, yes.  You'll either just work with the AMA-linked clips, or link them via AMA and then transcode them to whatever resolution you like.  Either method is faster than straight importing.  I can't think of a time when importing is preferable to AMA linking, or AMA linking followed by transcoding.
    And just to be pedantic, the phrase "AMA link for importing" might cause confusion, because in Avid-speak "AMA linking" and "importing" are two separate functions.
    patskehill:
    I think so, but I don't work with separate sound often, so I'll defer to someone who knows more about the workflow.
    Hope that helps.
    ciao,
    Carl
  • Fri, Jun 28 2013 1:41 PM In reply to
    Thank you so much for all you help. It really goes a long way.
    Patrick
  • Fri, Jun 28 2013 1:44 PM In reply to
    Also one more thing I forgot to ask. When I do the batch upres, which codec would be the best quality without being overkill?
    I shot on the 5d mk II in 1080p. It seems from what I have found on the thread that dnxhd 175 would be sufficient. But should I go higher, is there any need to.
    I am working in AMC 5.
    Patrick
  • Fri, Jun 28 2013 4:32 PM In reply to
    I'd pick the highest DNxHD resolution that won't eat up all your drive space.  What number that is will depend on your project type.
