Latest post Fri, Mar 15 2013 3:36 PM by Chris Cat. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Mar 5 2013 4:27 PM
    • Chris Cat
    • Joined on Fri, Dec 2 2011
    • Munich
    • Posts 6
    • Points 90
    Performance loss - 6.5.2 - LMCorrect
    Hi community,
    we got a huge problem using NuGen Audio LMCorrect (V1.1.0) since changing our systems to Avid Symphony 6.5.2
    With the new Avid version the audio suite plugin takes much more time for analyzing and rendering a stereo mixdown file in the timeline. Using Avid MediaComposer 5.5.2 it took  about 5min to analyse an 1h file. Now it takes more than 30min for the same file.
    We didn´t change any hardware, just software. We also tested the plugin in both versions (1.0 and 1.1.0) Windows 7 Professional (6.1 Service Pack 1) HP Z800 workstations with Avid certified hardware We recognized that the workstations are just using every second processor core while analysing.
    Does anyone have an idea / solution for this problem?
    Chris
    Avid Unity & ISIS 5000 15x Avid MediaComposer/Symphony MojoDX - PC V.5.5.3 / V 6.5.2 HP Z800/Z420 Avid certified Win7 HD-Workflow: 1080i25 - Professional... [view my complete system specs]
  • Wed, Mar 6 2013 11:38 PM In reply to
    • Posts 11,589
    • Points 256,010
    Re: Performance loss - 6.5.2 - LMCorrect
    Chris
    Hmmm you were on MC 5.5.2 and then upgraded to Symphony 6.5.2 right?  There will be some overhead with new features and the 32 bit versus 64 bit but it shoudldnt be that much.
    Let me see what I can find out.
    marianna
  • Thu, Mar 7 2013 1:31 PM In reply to
    • fsm
    • Joined on Tue, Nov 24 2009
    • Germany
    • Posts 181
    • Points 2,195
    same here with lm-correct & lm-h in audiosuite. MC 6.5.2 on a z420 and SYM 6.5.2 on my selfbuild pc.
    On MC 5.5 & MC 6.0 everything works fine & fast. no solution yet.
    MC 2021.12 & SYM / BM Monitor4K / Windows 11 (i know ...) 64 bit / i7 12700k / RTX3070 [view my complete system specs]
  • Thu, Mar 7 2013 2:34 PM In reply to
    • Chris Cat
    • Munich
    • Posts 6
    • Points 90
    Okay, with NuGen LMCorrect V1.1.0 (V1.0 license can be used) there´s a workaround:
    The V1.1.0 has a standalone version to be install on windows, use it!
    Use it like this:
    - Export your clip/tracks as .wav/.aif/.aiff out of your editing system
    - Start NuGen LM Correct standalone
    - Select your exported file and start analyze
    - After analyzed, start correction, a new file "-23,0LUFS" will be created
    - Reimport the corrected file back in your project
    This workaround takes the same time like it took with 5.5/6.0...
    Thanks to NuGen they applied the standalone :D
    But it shouldn´t be the final solution ;)
  • Thu, Mar 7 2013 5:35 PM In reply to
    • fsm
    • Germany
    • Posts 181
    • Points 2,195
    this cant be the final solution. there are lot of tools for loudness meter & correct outside from avid. we've buyed the nugen stuff for correct loudness inside avid.
  • Wed, Mar 13 2013 3:27 PM In reply to
    • fkurz
    • Joined on Wed, Jan 23 2008
    • Posts 32
    • Points 395
    hey!
    we had the same issue here and the solution was to change a nvidia setting. go to the nvidia control panel and turn on the enable overlay setting in the manage 3D settings panel. now our NUGEN plugins where as fast as usual.
    regards
    flo
    Avid MC 2018.12.10, symphony option HP Z820 Win 10 Mojo-DX Interface [view my complete system specs]
  • Fri, Mar 15 2013 3:36 PM In reply to
    • Chris Cat
    • Munich
    • Posts 6
    • Points 90
    fkurz:
    ...go to the nvidia control panel and turn on the enable overlay setting in the manage 3D settings panel....
    Okay, this works fine! :)
    Only thing you gotta watch out:
    Do it before you use EdPrep to clean up your system installation... afterwards you don´t have these options in nvidia cp any longer but changes are kept.
    Greetinxx
    Chris
