Latest post Tue, Jan 8 2013 10:09 PM by williamannau. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Dec 21 2012 1:20 PM
    • Posts 11,593
    • Points 256,090
    MC 6.5.2 and an Avid FX permissions problem
    For the first time in my life I have seen the following error message:
    I have done what I think I should do to change the permissions. But it has not helped.
    By the way, It is during the start up of MC that it suddenly aborts and shows the message.
    So now I cannot even boot MC for the time being.
    Regards,
    Douglas
  • Fri, Dec 21 2012 1:31 PM In reply to
    • Posts 11,593
    • Points 256,090
    Re: MC 6.5.2 and an Avid FX permissions problem
    Additional information
    It happens as "Initialising AVX Effects" appears under the splash screen
    Regards,
    Douglas
  • Fri, Dec 21 2012 1:38 PM In reply to
    • Posts 11,593
    • Points 256,090
    Now I have solved the problem!
    I had to change the shortcut properties, under Compatibility to Run this Programme as Administrator.
    Never had to do that before.
    I guess that is called "progress"  Stick out tongue
    Regards,
    Douglas
  • Fri, Dec 21 2012 1:58 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Seems like you just learned to always run Avid as system administrator Douglas Big Smile
    Tomas
  • Fri, Dec 21 2012 2:08 PM In reply to
    • Posts 11,593
    • Points 256,090
    mjolnarn:
    So true, Tomas
    But I have never had to think about that before with MC. The problem started directly after I updated to 6.5.2
    Regards,
    Douglas
  • Sat, Dec 22 2012 2:07 AM In reply to
    • eyeqjim
    • Arizona Goodyear
    • Posts 182
    • Points 2,405
    Douglas,
                     Scares me to think this new MC 6.5 has pulled a fast one on you...you are the most knowledgable person I know when it comes to Avid...Happy Holidays my friend.
    Avid Media Composer online Dell 7810 Dual Dell 17in monitors / DV keyboard [view my complete system specs]
    Cheers!
  • Sun, Jan 6 2013 10:09 PM In reply to
    Hi Douglas, A Happy New Year to you from Edinburgh!!
    I had the same problem as you when trying to run MC 6.5.2. Did you simply change the shortcut properties when logged on as a normal administrator or did you set up the hidden administrator account? I rolled back to 6.5 and haven't yet tried 6.5.2 again.
    Thanks very much for all your excellent contributions to the forum - you are a true godsend to many.
    Very best regards
    Bill Annau ACI
  • Tue, Jan 8 2013 3:22 PM In reply to
    • Dennis
    • Joined on Mon, Jul 6 2009
    • Posts 77
    • Points 855
      Avid Certified User
    Yes, In an educational system 60 workstations running at the adminstrator makes a lot of sense.  Stick out tongue
    2012 Mac Pro 2 x 2.22, 128 GB Ram, Vega 64 [view my complete system specs]
  • Tue, Jan 8 2013 9:09 PM In reply to
    • Posts 11,593
    • Points 256,090
    williamannau:
    To be honest - I don't remember.
    However, as I don't know how to set up a hidden administrator account, I am guessing it must have been done as a normal administrator.
    This was the first time in my Avid history that I have had this problem. So after I eventually got it fixed - I forgot how I did it.  Hopefully the problem will not pop-up again when a new update or upgrade comes along. I have certainly not seen it requested here on the Forums as a "new feature"! Stick out tongue
    Regards,
    Douglas
  • Tue, Jan 8 2013 9:27 PM In reply to
    drbgaijin:
    I have still never seen this problem with Avid Douglas. (But I am installing it as an Administrator in a server based network environment.)
    FWIW I have seen the problem several times with different parts of Adobe's CS4 (Encore in particular)
  • Tue, Jan 8 2013 10:06 PM In reply to
    • Posts 11,593
    • Points 256,090
    AndrewAction:
    If I may "speculate" for a moment, Andrew
    I think that 99.999% of Avid users never have this problem.
    I have never had it until this install, so my immediate feeling was that something had changed with the installer.
    But that does not necessarily follow. It was just my first reaction to seeing this problem for the first time.
    Now things are running again, I have almost already forgotten about the event
    Regards,
    Douglas
  • Tue, Jan 8 2013 10:09 PM In reply to
    Hi Douglas,
    Thanks for responding. The only reason I mentioned the hidden administrator account was that when I previously had to install some software on a Unity server I had to activate the hidden admin account otherwise it didn't work. It's activated via command prompt then just type in : net user administrator /active:yes.
    There's always something new to learn. It makes life interesting.
    Best Regards
    Bill
