I just open and my Symphony freezing. often before I've even started editing. I click on the timeline or something and the egg-timer icon comes up and it's game over. I need your help, what I need to do? I have three internal Hard drive of 3tb each, the media is in hard drive number 1 and my symphony is in hard drive number 1 too
Steve Bocaranda:I have three internal Hard drive of 3tb each, the media is in hard drive number 1 and my symphony is in hard drive number 1 too
That's your problem. You need to store media files on a DIFFERENT drive than the drive the application is installed and run on. You are overtaxing your drive. The standard configuration is for the Symphony application to be installed and run from the system drive and media written to a separate drive, either internal, external or a RAID array.
Ok I'm going to try it, and I let you know
Keep in mind the Avid Media Folder Management Ground Rules:
1) The "Avid MediaFiles" folder (for MXF media) and the "OMFI MediaFiles" folder (for OMF media if you have any) MUST reside at the root level of the media drive, not inside any other folders or the system will not be able to find the media.2) The folder names must always be the factory default names listed above (minus the quotes) or the system will not be able to find the media.3) There can be only one of each folder type on any given media drive.
And after moving media between drives, you will need to rebuild the media database files to update the system as to the new location of the files, or you will get media offline warnings. Quit the application, and in each numerical folder inside the MXF folder inside the Avid MediaFiles folder, delete the two files that identify as "msmFMID.pmr" and "msmMMOB.mdb". If you have an OMFI MediaFiles folder, delete the same two files. On re-launch, the system will detect the missing files and build new ones at the "Initializing Media Streams Manager" stage. You will see the system go into scanning and then indexing modes at this point. Depending on how many drives and how much media you have on your system, this can take a while, so good time for a meal break.
I FIXED IT, the problem is when you have a clone hard drive in the same computer. Apple check for me, thay removed the buck up hard drive and now is working perfect.
