Latest post Mon, Nov 5 2012 3:18 AM by Ra-ey Saleh. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Oct 24 2012 2:15 PM
    • endavid
    • Joined on Fri, Aug 3 2012
    • Posts 12
    • Points 140
    Best XDcam Ingest solution
    Hi
    I'am looking for the best tools to ingest XDcam disc on a Unity. I have some PDW U1 and HD1500 deck. The idea is to dedicated a simple Windows based PC to do this task. During this time, others mediacomposer systems are free for editing. If I can rename clip before ingest, it's a good thing.
    I have tried SAT AI "Autoingest direct" witch is a perfect tools for that but the price ($4600) is too expensive :(
    I have tried opencube "ENGSoft" but It needs interplay and I don't have it
    Any ideas ?
    best
  • Wed, Oct 24 2012 3:18 PM In reply to
    Re: Best XDcam Ingest solution
    Download XDCam Browser from the Sony site.  You can rename discs, rename clips, add Essence Marks to clips, and a lot of other things.  Including copying an entire disc to another ocation or even just copying a clip to another location.
    Even better is that it's free.
  • Thu, Oct 25 2012 8:02 AM In reply to
    • endavid
    • Posts 12
    • Points 140
    Yes, I know it, but I don't need browsing function. Only simple and quick rename clip function. After that I want to directly converted xdcam file to MXF op atom file ready to use with mediacomposer.
    Also xdcam browser don't allow you to connect more than one XDcam Deck to one machine.I have 4 x HD1500 deck on LAN and I want to use it simultaneously to ingest faster.
  • Thu, Oct 25 2012 2:34 PM In reply to
    • Haze
    • Posts 764
    • Points 10,245
    endavid:
    You can't ingest more than one stream at a time.  You could look at MOG Solutions MXF Speerail, but it's likely out of your budget range.  Kenton's suggestion of using XDCAM Browser is the lowest cost solution.
    Regarding renaming, I'm guessing that you are working clips named C00010, C00011, etc.  The XDCAM cameras are capable of having a custom title prefix.  Once set up in camera the clips can be autonamed according to the prefix setting.  For example if the shoot is a Auto Show the clips could be named AutoShow001, AutoShow002, etc.  or CAM1_0020, CAM1_0021...CAM2_0014, CAM2_0015, etc.
    You may not have any control of production, I'm simply suggesting this because sometimes post problems can be fixed upstream.  How about "Fix it in Production" rather than "Fix it in Post" ?
    Avid DS 11 | Z800, Symphony 6.5 | HP xw 8600, MC 6.5 | HP Z400, Unity Storage [view my complete system specs]
  • Thu, Oct 25 2012 2:50 PM In reply to
    With every license of Media Composer and Symphony comes Interplay Transfer (PC Only).  you can run Transfer ON YOUR Edit station in the background and have it do FTP pulll from your HD1500 Decks using FTP Clip Browser to have your Avid dump it right into your bins and the Unity/ISIS.
    Since it will use your host computer for the transfer, the database files are updated by your MC/TM software.
    http://avid.force.com/pkb/articles/en_US/user_guide/Avid-Interplay-Transfer-Setup-and-User-s-Guide-v2-6?popup=true&NewLang=en&DocType=1082
    Media Composer 8.2 Dongle+Symphony Option Win7x64 Pro HP zBook 15" Laptop - 16GB RAM (2nd System) Media Composer 8.2 Dongle+Symphony Option - HP z420... [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Mon, Oct 29 2012 10:15 AM In reply to
    • endavid
    • Posts 12
    • Points 140
    thanks you all for yours answers.
    I dind't think about Interplay transfer but it's a very good suggestion.
    I will test it and post results :)
  • Mon, Nov 5 2012 3:18 AM In reply to
    Great tip Big Smile
    Ra-ey
    Symphony Nitris v7, Media Composer v7, Artist Color, ISIS v4.1, Unity MediaNetwork v5.4, Sapphire v6.1, Boris Continuum Complete v8.1.1, AvidFX... [view my complete system specs]
    Media Composer 6 Certified User
    Media Composer 6 Certified Professional
    ra-eysaleh.com
    LinkedIn
    Showreel
