Latest post Tue, Oct 16 2012 3:52 PM by ingofoertsch. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Oct 2 2012 4:28 PM
    • richiebh
    • Joined on Mon, Jun 6 2011
    • Posts 8
    • Points 100
    AMA LINKING PROBLEMS..
     I am encountering problems linking to AMA on CanonXF. I've been able to transcode some of my rushes but the remainder throw up this error message and crashes out of AVID:
     'DIDDescriptor: GetAAFProperties: XDCAMHD Unsupported resolution'
     I don't know what more plug-ins there are for me install. I'm using MC6.. Any takers?!
    Filed under: , ,
  • Tue, Oct 2 2012 5:09 PM In reply to
    • Brian Suttie
    • Edinburgh, Scotland
    • Posts 917
    • Points 11,725
    Re: AMA LINKING PROBLEMS..
    What frame rate / size is the footage and what project are you in?
    If you're unsure of the footage take a look at it in Canon's XF Utility to check frame rate and size.
    regards
    Brian
    "We'll fix it in post"
    "This is post"
    "aaaahh"
  • Tue, Oct 2 2012 6:42 PM In reply to
    You need to have both the Canon XF and the Avid MXF Plugin for this camera to work.
    Links to AMA plugins can be found here.
  • Wed, Oct 3 2012 9:33 AM In reply to
    • richiebh
    • Posts 8
    • Points 100
     Thanks for getting back to Brian.
     I'll check throught the settings again and check again for the latest plugins. Spec is Frame Rate: 24.00p, 1920 x 1080, 50 Mbps..
     Cheers
     Richie
  • Wed, Oct 3 2012 9:34 AM In reply to
    • richiebh
    • Posts 8
    • Points 100
     Thanks Kevin. I seem to have all the piug-ins though.. Will check for updates.
     Cheers
     Richie
  • Wed, Oct 3 2012 11:12 AM In reply to
    • richiebh
    • Posts 8
    • Points 100
    Rumour has it that Canon haven't updated the pluggin yet on MC6 for linking to the C300 at 24.00p fr..
  • Wed, Oct 3 2012 4:22 PM In reply to
    • Brian Suttie
    • Posts 917
    • Points 11,725
    I believe that's correct, Canon do suggest using 23.976 for most purposes :
    Warning — 23.98 fps vs. 24.00 fps
    EOS C300 cameras allow users to choose two frame rates that at first glance appear to be “24P”.
    For conventional digital video recording at “24P”, users normally want to actually be shooting
    at 23.976 fps. To accomplish this, proceed as indicated directly above (MENU > Other Functions
    > Frame Rate), and choose 23.98P.
    However, for video recording which must be precisely tied to existing 24.00 fps film footage,
    there’s a completely separate fps setting:
    MENU > Other Functions > 24.00p
    It cannot be over-emphasized — the 24.00P setting is NOT for general-purpose video
    recording. DO NOT set 24.00P unless you deliberately intend to match video files
    with existing film footage which was shot at 24 fps in a film camera, or unless postproduction
    staff have specifically instructed camera operators to use this setting
    instead of 23.976P.
    One workround for 24fps Canon material is to use Sorenson Squeeze to transcode to DNxHD
    regards
    Brian
    "This is post"
    "aaaahh"
  • Wed, Oct 3 2012 4:52 PM In reply to
    • richiebh
    • Posts 8
    • Points 100
    Thanks Brian. This is a great help.
    Richie
  • Wed, Oct 3 2012 7:27 PM In reply to
    • Jim
    • Joined on Sun, Jun 3 2012
    • Bloomington, IN
    • Posts 21
    • Points 225
    I've used AMA to link to CanonXF305-generated MXF clips with no problems (at least with the linking aspect). You might already be doing this, but be sure that the entire folder structure is intact. Link to the directory one level up from the "contents" folder.
    Good luck
    Media Composer 6.0.3, MacPro(4,1), 2 x 2.26 Quad-Core Intel Xeon, 16GB RAM, OS 10.8.2, NVIDIA GeForce GTX680 [view my complete system specs]
  • Tue, Oct 16 2012 3:52 PM In reply to
    • ingofoertsch
    • Bavaria, Germany
    • Posts 91
    • Points 1,165
    Hi, i also encountered the same thing.
    I shoot on a C300 with the overall 24P setting.
    I was shooting for a company doing Cinema-Ads in 24P for a digital cinema projekction system.
    Premiere Pro seems to work with these MXF files with no problem.
    But there is no way getting the into the MC 5.5.3 on OSX 10.6.8 which i am currently on.
    No AMA, no import - nada.
    Waht is the problem with these files?
    Why should i have been shooting 23.something?
    ingo
    1. Imac 27", OSX High Sierra, MC 2018.9.0 2. Imac 27", OSX High Sierra, MC 2018.5.0 [view my complete system specs]
    My system: MC 8.5.3 / Mojo DX / MacPro 2x 2,66 Nehalem / 32 GB Ram / OSX 10.9.5 / NVIDIA GeForce GT 120
