Latest post Sun, Sep 9 2012 9:27 PM by renricker7. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Wed, Sep 5 2012 10:34 PM
    sony nex-7 - avchd to dnxhd with tmpgenc 5 - problems
    hello,
    i am trying to find solutions to that encoding problem since 2 days, but nothing seems to work out well.
    i now chose to go with tmpgenc, wich seems to be the best solution ...
    here are the facts:
    win 7
    avid mc adrenalin 3.5
    TMPGEnc Video Mastering Works 5
    camera sony nex-7
    resuslutions of cam:
    avchd
    1.920 x 1.080 (50p, 28 Mio., PS), 1.920 x 1.080 (50i, 24 Mio., FX), 1.920 x 1.080 (50i, 17 Mio., FH), 1.920 x 1.080 (25p, 24 Mio., FX), 1.920 x 1.080 (25p, 17 Mio., FH)
    mp4
    1.440 x 1.080 (25 fps, 12 Mbit/s), VGA (640 x 480, 30 fps 3 Mbit/s)
    i tried sooo many option, but ether the imported file was shaky (p) or they were striped (i) in avid.
    i am looking for solutions for future projects, so i could film in any of the mentioned formats, preferable the highest resolutions. wich should i choose and what is the exact workflow to convert them into a file wich doesn´t shake and shows stripes in avid.
    i would be very, very happy, if you could give me the most detailed explanations, cause i have no clue at all about the whole situation.
    ahh, i forgot ... it is quite urgent to me!!!
    thank you very much!
    rené
    Filed under: , , ,
  • Thu, Sep 6 2012 10:21 AM In reply to
    Re: sony nex-7 - avchd to dnxhd with tmpgenc 5 - problems
    nobody has an idea?!?
    would be great, as i am without a clue and have no idea of how to go about it ....
    thanks for the effort!!!
    rené
  • Thu, Sep 6 2012 10:44 AM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,780
    The easiest way I've found to import AVCHD files into MC is to link them via AMA, then Transcode to DNxHD. I've tried transcoding, first, with Adobe Media Encoder, but, my audio ets corrupted by doing it via AMA.
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Thu, Sep 6 2012 10:57 AM In reply to
    am i right to guess that you don´t use mc 3.5? as i was checking for compatiblity with 3.5 and it does´nt support this plug-in ...
    am i right?
    rené
  • Thu, Sep 6 2012 2:13 PM In reply to
    Are you seeing problems on the monitor connected to the adrenaline or inside the MC UI?
    Jeroen van Eekeres
    www.mediaoffline.com
  • Thu, Sep 6 2012 8:36 PM In reply to
    the problem is not seen inside adrenalin ui, there it looks perfect, but it looks very bad at the monitor that is connected to avid ...
    any ideas?
    rené
  • Thu, Sep 6 2012 9:15 PM In reply to
    While it might sound weird... that can be normal. The UI video monitors do, by default, not show you both fields and depending on your UI video display quality settings (yellow/yellow, yellow/green, green/green) they will not show all video information.
    The only reliable video display to judge if your comversions are ok is by using the HD-SDI or DVI output on your Adrenaline to a HD monitor.
    If it looks good there you're ok.
    Jeroen van Eekeres
  • Thu, Sep 6 2012 10:47 PM In reply to
    yeah, this is something that i agree to, but the problem is that it doesn´t look good at the monitor. thats why have those questions ...
    how can i preset the converter in a way that it looks good after the conversion.
    any idea?
    rené
  • Fri, Sep 7 2012 9:36 AM In reply to
  • Fri, Sep 7 2012 10:11 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    First and of most importance, TMW 5 is only one of many encoding applications out there, to what codec have you transcoded your Avchd media and what settings was used ?
    Tomas
  • Fri, Sep 7 2012 3:56 PM In reply to
    thanks for the hint ... wich other encoder do exist wich work well?
    i tried to convert into dnxhd, as the topic mentions ... i think it doesn´t matter wich settings i used, cause they were not satisfying.
    what is the rigth workflow to get the propper results?
    anybody?
    please answer only the question if you used or know how to use the combination of mc 3.5 adrenalin and tmpg5 and know the propper workflow!
    everything else is timeconsuming and doesn´t bring results!!!
    thanks!
    rené
  • Sun, Sep 9 2012 6:43 PM In reply to
    seems to be not so easy to overcome the problem ... not anyone?
    thanks,
    rené
  • Sun, Sep 9 2012 6:50 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    renricker7:
    Users with both MC 3,5 Adrenaline and TMW 5 at the same time might be considered rare .
    Tomas
  • Sun, Sep 9 2012 6:51 PM In reply to
    Desktop
    Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Quadro P2000|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
    Laptop
    MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)
    NLE
    DR Studio 18.1|MC 2022.10
    3 Heads Digital Films
  • Sun, Sep 9 2012 7:06 PM In reply to
    mjolnarn:
    renricker7:
    i can imagine, but this is how it is ... :-)
    rené
