Latest post Wed, Jan 23 2013 7:28 PM by slabross. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Jul 16 2012 3:24 PM
    • Richard Riley
    • Joined on Wed, Jan 11 2012
    • Evansville, IN
    • Posts 28
    • Points 360
    Timewarps with speed changes not transfering
    Help Help Help.  I have upgraded to DS 11. I have imported an AFE from both MC 6.0 and MC 6.0.1.1 and they both will not transfer the Timewarps with speed changes correctly. Am I the only one haveing this problem?
    Richard
    Madstache
  • Mon, Jul 16 2012 3:52 PM In reply to
    • slabross
    • Montreal, Quebec, Canada
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    Re: Timewarps with speed changes not transfering
    The Conform Guidelines for Avid DS report Timewarp effects in the "B" rank support level, and that means that not everything is guaranteed to conform fully.
    On Media Composer, make sure that the anchor point is set at the beginning of the timewarp or that can be enough to break the conformed effect in DS.
    Sylvain Labrosse
    Principal Expert | Services and Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    Create cases online now at  csportal.avid.com
    It's fast, easy and effective!
    We're Avid.  Learn more at www.avid.com
  • Mon, Jul 16 2012 7:58 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,091
    • Points 49,325
    I think it would be adviseable to have a discussion with Avid Marketing:
    http://www.avid.com/US/products/avid-ds
    'Eliminate editorial rework
    Fully conform high-res sequences from Media Composer 6 and Symphony 6"
    The OP has pointed out one of the fallacies of that statmement.  "Fully Conform" is a pretty strong statement.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2021 iMac w Big Sur [view my complete system specs]
    Jef Huey
  • Tue, Aug 7 2012 11:13 PM In reply to
    • AGT21
    • Joined on Wed, Apr 14 2010
    • Posts 11
    • Points 135
    No, you are not the only one and I am sad to see it hasn't been fixed in v11. A temporary fix for us is to open the sequence in Composer 4.05 and export from there. 5.5 would probably work fine as well.
  • Wed, Oct 24 2012 10:50 PM In reply to
    • Andrew_G
    • Joined on Tue, Jul 5 2011
    • Posts 13
    • Points 145
    We're also having this issue. MC6 to DS11 breaks the timewarp. Very frustrating considering MC4 to DS 10.3 worked just fine. PLEASE fix this.
  • Thu, Oct 25 2012 2:10 PM In reply to
    • slabross
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    Andrew_G:
    PLEASE fix this.
    The upcoming 11.0.2 update release will address the Advanced Keyframe changes in Media Composer that broke Timewarp conforms in DS.
    Avid DS 11.0.2 availability will be announced on the Avid Community when released.
    Sylvain Labrosse
    Avid
    Canada
  • Thu, Oct 25 2012 7:51 PM In reply to
    • Andrew_G
    • Posts 13
    • Points 145
    Thanks, Sylvain. Good to know a fix is coming.
    Any idea when we can expect this update?
  • Thu, Oct 25 2012 9:12 PM In reply to
    • slabross
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    Soon...
    Sylvain Labrosse
    Avid
    Canada
  • Fri, Oct 26 2012 4:05 PM In reply to
    • jef
    • Maryland
    • Posts 4,091
    • Points 49,325
    Are we there yet?    Smile
    Jef Huey
  • Wed, Jan 23 2013 6:21 PM In reply to
    • Richard Riley
    • Evansville, IN
    • Posts 28
    • Points 360
    Yes 11.0.2 with exporting from MC6.5 Fixed the bad timewarp transfers. All is good now.
    One issue reamains with the conforms. If the MC AFE has any timewarps that have cuts as transitions then there is a black frame left in between clips. This is happening in 720P projects from MC to DS. Any Idea when this will be addressed.
    Richard
    Madstache
  • Wed, Jan 23 2013 7:28 PM In reply to
    • slabross
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    Can you open a support ticket with Avid and provide some AAF or AFE samples to help reproduce this issue?
    Sylvain Labrosse
    Avid
    Canada
