Latest post Tue, Jul 3 2012 9:28 PM by Sylvain P. 2 replies.
  • Tue, Jul 3 2012 3:45 PM
    • antsquasher
    • Joined on Fri, Jan 13 2012
    • London, UK
    • Posts 8
    • Points 80
    Audio Stretching
    Hey,
    I'm curious to know if there is an effective way of slowing down and stretching audio without mixing down my audio at all?
    I have a clip shot at 100fps w/a 24fps TC and audio recorded with a 24fps TC too,
    I want to slow down the audio and stretch it to fit the duration of my 100fps shot.
    I understand I could cut the audio into a sequence, add filler, mix it down, then apply the TImeshift effect and stretch the audio to fit that way, but its so long winded and I dont want to be dealing with mixdowns.
    Any alternative suggestions?
    Many Thanks
  • Tue, Jul 3 2012 7:59 PM In reply to
    • Kyle
    • Joined on Tue, May 29 2012
    • Posts 135
    • Points 1,700
    Re: Audio Stretching
    If you open up the audio suite tool there's a filter that will do that. I forget what it is called though.
  • Tue, Jul 3 2012 9:28 PM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,493
    • Points 17,680
    In the AudioSuite Window, you have Time Compression Expansion and Time Shift.
    Time Compression Expansion : Set the Ratio to 4.1667 (I think)
    Time Shift : Set the Pitch shift to (probably) 24%
    Media Composer 2021.5 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. BCC 10, Boris... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
