Latest post Tue, May 15 2012 1:58 AM by Kale. 5 replies.
Page 1 of 1 (6 items)
  • Mon, May 14 2012 6:02 AM
    • Kale
    • Joined on Thu, Jan 19 2012
    • Posts 10
    • Points 130
    Avid FX Key frames
    Hi All
    I cant seem to work out keyframes in Avid FX. I need to move a small logo from one one side of the screen to the other.
    Some links to any basic key framing tutorials would be much appreciated.
    I think i may have turned off avid FX's ability to automatically create keyframes when a parameter is adjusted.
    Thanks in advance,
    Kale.
  • Mon, May 14 2012 9:29 AM In reply to
    • TrevorA
    • Posts 1,348
    • Points 15,280
    Re: Avid FX Key frames
    Start position (nothing changed)
  • Mon, May 14 2012 9:32 AM In reply to
    • TrevorA
    • Posts 1,348
    • Points 15,280
    Pictured moved to the left (note change in X Position).
    Motion is set to 'constant' ( .... ) - this is good if you don't want to keyframe - anywhere you change this position will not add a keyframe and thus will not animate. If you want to add a keyframe change the motion type to something else...
  • Mon, May 14 2012 9:34 AM In reply to
    • TrevorA
    • Posts 1,348
    • Points 15,280
    Here I've changed it to 'linear' ( / ) - this will add a keyframe
  • Mon, May 14 2012 9:41 AM In reply to
    • TrevorA
    • Posts 1,348
    • Points 15,280
    Go to a different position in the timeline - change the horizontal position and set the animation style to 'hold' ( - ). This will hold this x position from this 2nd keyframe until the next keyframe / end of comp. This should now animate between Kfs 1 and 2 in a linear fashion.
    (It may well animate between the beginning of the comp and your first Keyframe - I don't quite understand the Boris approach here, but would just copy the first PosX keyframe to the beginning of the timeline and set the motion to 'hold'.)
    Mods should probably move this to the 'Complete Your Suite' forum as that is where Dirk from Boris monitors...
  • Tue, May 15 2012 1:58 AM In reply to
    • Kale
    • Posts 10
    • Points 130
    Thanks a lot TrevorA.
    That was the problem i was having. Now i get it.
    Cheers,
    Kale.
