Latest post Tue, Feb 28 2012 12:50 PM by Ian Stockdale. 3 replies.
  • Fri, Feb 24 2012 12:07 PM
    • Ian Stockdale
    • Joined on Wed, Jun 3 2009
    • Plymouth U.K.
    • Posts 38
    • Points 470
    MPEG IMX QT Codec
    Research told me that the IMX codec was in the MC QT codec PE installer.  As many others seem to say, when installed a PE directory is made but it seems to contain nothing?  Is the ONLY answer to buy a commercial codec?
    HPxw8400 workstation, Twin 3Ghz Xeons, 5G RAM, Win 7 pro 64 bit, NVidea Quadro FX1500, 2xWD500 3x Seagate Barracuda 1TB SATA's, Texas instruments OHCI... [view my complete system specs]
  • Fri, Feb 24 2012 9:23 PM In reply to
    • Kristina
    • Joined on Sun, Nov 28 2010
    • Germany
    • Posts 463
    • Points 5,620
    Re: MPEG IMX QT Codec
    not sure what you are trying to do.
    Are you looking for an opportunity to capture to IMX codec or to playback IMX-files? Talking about MC or another standalone PC?
    Best regards,
    Kristina
    several z800 and xw8600 Nitris DX, MC v.5.5.3, Win XP Prof SP3, ISIS-5000 16TB with Force 10 Switch 10Gig, several MOG S1010 ingest servers, several EVS... [view my complete system specs]
  • Sat, Feb 25 2012 6:25 PM In reply to
    • Ian Stockdale
    • Plymouth U.K.
    • Posts 38
    • Points 470
    Just trying to import a short title sequence which is QT mpg imx into Avid.  A commercial codec works (watermarked) but the PE installer appears to do nothing.
  • Tue, Feb 28 2012 12:50 PM In reply to
    • Ian Stockdale
    • Plymouth U.K.
    • Posts 38
    • Points 470
    The Calibrated Q codec works fine on replay and import into Avid but the Avid PE imx codec plays audio with a white (blank) screen.  Despite making an empty installation folder the PE codec CMAvidMPEG2IMXCodec.avx is installed the Avid codec folder.
    Filed under: ,
