Hi fellow forum users,
I am having a lot of trouble with my AVID product and have had it for quite some time, and i dont know how to solve it.
First i will post the information i know:
Product: AVID Media Composer 4.0.5Windows: MS Windows XPComputer: HP xw8400 workstationRAM: 2.7 GB
The errors i get are the following:
1.
Title: ErrorDescription: An access violation exception occured. For more information see errorlog: c:\documents and settings\all users\documents\avid media composer\avid fatalerrorreports\exception 2012.01.12.36.58\
I can only press OK on this error.
Afterwards i get the next error:
2.
Title: Exception: Structured ExceptionDescription: ExceptionCode: 0xc0000005, ExceptionString:ACCESS VIOLATION, FaultAddress: 0x2b6f23b, MInidumpFileName:4f3b10a2-bef5-4267-af36-72bd9acb073e.dmp
I can press OK on this error too, but then the computer freezes. Sometimes i can get it to unfreeze again, sometimes not. Its quite frustrating since i have to deliver a project very soon to a customer.
Has anyone experienced this error before - and what can be done?
Thanks in advance for all your help and time :)
Which exact version of Windows XP? Pro or Home? Any Service Packs (SP) installed?
"There are few technological barriers. You can fix almost anything if you throw enough money at it."*******************************Randall L. Rike, ACI, ACSR Mac*Win*Unity*ISIS*DSSystems Engineer @ BET Networks [a Viacom company](wwld)
The version is Pro and SP1 afaik :)
Could it have something to do with this? Or is the problem related to something else?
The MC Version Matrix specifies Win XP Pro SP2 or SP3, QT 7.6.4, nVidia 190.38. Your SP1 may or may not be at fault. More than likely, it's a permissions isue. See this Knowledge Base article.
Okay - an update on what ive tried.
AVID media composer is crashing almost all the time with the error that i posted originally. i have checked the versions of QT, Windows Update and drivers - and all live up to the required specifications.
The graphics card has been replaced and so has the external harddrive that the projects are saved on. So it cannot be those parameters.
I have also checked whether simple filesharing is enabled and it IS NOT!
Last but not least i have reinstalled avid media composer without any change in condition.
So im getting a bit frustrated!
I am pasting the logfile to which the error is pointing to.
________ Exception Report ________________________
Exception Code: C0000005 ACCESS_VIOLATION
Fault Module: 01:0011AD5B C:\Program Files\Avid\Avid Media Composer\ameLibrary.dll
Fault Address: 02B7BD5B MPEGAudioDescriptor::GetNthSupportedBitRate+A1B
________ Stack Dump _________________________________________
02B7BD5B 18572B14 MPEGAudioDescriptor::GetNthSupportedBitRate+A1B
03063B34 03063B54 APlayer::`vftable'+0
02F83D36 02F83D3C VideoDescVisitor::DoCheck+13186
25FF02FD 1C7C25FF Symbol Not Found - Error 0000007E(00000126)
0F342444 8B6C2444 Symbol Not Found - Error 0000007E(00000126)
AVID SYSTEM DUMP - Thu Jan 12 19:31:41 2012
________ Memory ________________________________________________________
numPtrs: 207747
numHdls: 07033
totalPtr: 0x03e3b646 (65254982)
totalHdl: 0x00070d10 (462096)
________ Current Program Stack _________________________________________
7C90E514 0012DBBC KiFastSystemCallRet+0
6039A510 0012DBCC PSPrintStack+70
6031480B 0012DC5C DmpDump+9B
60314D3B 0012DF14 DmpDumpToFile+3CB
60319F90 0012E4CC AvRgn::InternalHRGN+EF0
6031B098 0012E534 AvRgn::InternalHRGN+1FF8
7C359C97 0012E57C _CxxLongjmpUnwind+EA
7C359629 0012E5AC _CxxExceptionFilter+1C4
7C3598AD 0012E604 _CxxExceptionFilter+448
7C35994A 0012E634 _CxxExceptionFilter+4E5
7C359B9D 0012E66C _CxxFrameHandler+26
7C9032A8 0012E690 RtlConvertUlongToLargeInteger+6A
7C90327A 0012E740 RtlConvertUlongToLargeInteger+3C
7C90E48A 18572B14 KiUserExceptionDispatcher+E
________ System Configuration __________________________________________
System software: Windows NT Version 5.1 Build 2600 Service Pack 3
Processor type: Pentium PC
Physical Memory: 3327 MBytes; Virtual Memory: 2699 MBytes
User name: Administrator
Application info: Hitchcock_Release_R10910
________ Processes Currently Running ___________________________________
________ WindowList ____________________________________________________
________ Binary Modules Loaded _________________________________________
________ Device Drivers Loaded _________________________________________
I am getting same error and I am only playing back the media on the timeline and my other PC is getting this same error when trying to save the project which doesn't seem to let me save it.
Anyone has an idea?
read the other posts here. Also we need system specs before any usefull answer can be given. Detailed please hardware and software.
http://www.AvidUserGroup.NL fcp2avid "The Technology Is Not Guilty" - Nicolas Philibert quoted in "Documentary in the digital age" by Maxine Baker (2006)
HP Z400 Windows 7 Pro 64Bit. Media Composer v5.5 and for the media I am using the G-Raid ES connected via the SATA and it is a Raid 0. I understand what others have suggested in the forum which I already have read the other posts but no solution yet.
The only solution I have come up with so far is to delete the Database files and re-boot which seems to have fixed the issue for awhile and then eventually it does start doing the same thing which forces me to do the same process over again.
Regards
I did say detailed specs :) SO what hardware, what software, quicktime version, sound card, graphics card, driver versions ect.
