Latest post Mon, Jan 11 2021 7:40 AM by Sam Beckett. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Oct 24 2011 7:32 PM
    • phatratpak
    • Los Angeles, CA
    • Posts 42
    • Points 440
    Locators in EDL
    I need to either add comments or add locators to my sequence for reference in an EDL that will accompany an Inferno session.  So far everything has gone smoothly until this last time.
    I prefere locators because I can generate nice clean lists to print and what-not, plus it gives nice visual cues as to where notes are.
    However this most recent time, some locators (very arbitrarily) will not show up on my EDL.  My work around was to add comments to these clips and have the EDL show comments as well, however, I would like to not have to do this.
    Anyone have any info?  Is there a characer limit to locators?
    I am at work and do not know the all the hardware specs but am using OS10.5.6, 2.2.66GHz Quad-Core, MC3.1.3 & ELDManager 24.1.3.
    Much abliged as always...
    Media Composer 5.5.3 / OSX 10.6.8 /MacBook Pro 17-inch 2.3GHz Quad-core Intel Core i7 / 8GB 1333MHz DDR3 SDRAM - 2x4GB / 500GB Serial ATA Drive @ 7200... [view my complete system specs]
  • Mon, Oct 24 2011 9:52 PM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,585
      Avid Employee
      Moderator: Film
      Moderator: MetaFuze
    Re: Locators in EDL
    I could see one limitation being that comments are one line length in EDL, so less than 70-80 characters if my memory serves me correctly. Is the itent to have the locators in the EDL that gets imported into the Inferno, or just to have man-readable?
    Michael
    24p.com
  • Mon, Oct 24 2011 10:05 PM In reply to
    • phatratpak
    • Los Angeles, CA
    • Posts 42
    • Points 440
    Re: Locators in EDL
    Thanks for the response.
    I believe it's more to have man/woman- readble Smile.  So the end result I want is to have my locators show up in the EDL as they should.  I just spoke with another editor and he said he has the same problem so resigned himself to duplicating his locator notes as clip comments.
    Also we're editing in 23.976/1080p projects if that's relevant or helpful.
    Very weird?!?
  • Mon, Oct 24 2011 11:22 PM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,585
      Avid Employee
      Moderator: Film
      Moderator: MetaFuze
    Re: Locators in EDL
    If you are looking at wo/man-readable lists, I have used FilmScribe to export a variety if formats. It also has filter for:
    1. All events and locators
    2. only events with locators
    3. show locators only
    4. show event with locators but not locators.
    5. etc.
    The link is a zipped file of several examples: a PDF from the HTML version (hyperlinked), XML, Tabbed, and basic printout. the setting for the locators was only show events with locators and show locators.
    http://dl.dropbox.com/u/1226998/LISTS.zip
    Michael
    24p.com
  • Tue, Oct 25 2011 10:11 PM In reply to
    • phatratpak
    • Los Angeles, CA
    • Posts 42
    • Points 440
    Re: Locators in EDL
    Thanks Michael.
  • Tue, Sep 16 2014 8:45 AM In reply to
    Re: Locators in EDL
    It's a really old thread, but I've had this same problem a couple of times, and both times eventually worked it out ... locators on GROUP CLIPS don't seem to show up in an EDL. Replace the GROUP CLIP with just the source you want (is there a quick way of doing this?) and then your locators will show up fine.
  • Mon, Jan 11 2021 7:40 AM In reply to
    Re: Locators in EDL
    It took forever, but in Media Composer versions 2018.12.14, 2019.12.3, and 2020.12, you no longer have to Commit Multicams for Markers to display on Groups!
    • MC 2022.7 • MacBook Pro (16-inch, 2021) [OS 12.4 | M1 Max | 64 GB RAM ] ##### • MC 2018.12.15 [NEXIS 19.8.0.2 | Avid Artist DNxID] • iMac Pro... [view my complete system specs]
