Latest post Tue, Oct 25 2011 2:10 AM by MichaelP. 4 replies.
  • Mon, Oct 24 2011 3:17 PM
    • BlueGirl Media
    • Joined on Tue, Apr 25 2006
    • Glasgow, Scotland (UK)
    • Posts 143
    • Points 1,960
    Alexa Workflow
    Hello Guys,
    Looking for some input on this workflow. All comments very welcome.
    Camera is shooting ProRes 4444 Log C @ 24fps. Audio Mono Mix going to camera & 8 channel master audio delivered on DVD.
    DIT will supply QuickTime Wrapped DNx36 with LUT applied and ALE file. (Can't do MXF wrapped).
    1. Project Settings - 1080p/24, RGB (Is RGB the correct option for this?)
    2. Import ALE
    3. Batch Import DNx36 QuickTime clips via ALE
    4. Sync & Sort
    5. Edit
    Online
    6. Force DNx36 Media offline
    7. Select Sequence and revel referances in bin
    8. Select offline master clips
    9. Batch Import (pointing to ProRes QuickTime files & import as DNx185x/Uncompressed 10bit)
    10. Grade & Output
    Ideally I'd like to go AMA but editor prefers to work with LUT'ed footage.
    Many Thanks
    G.
    Dual 2.7GHz G5 | 5GB RAM | SIIG Firewire 400 | MC 2.8.3 | Mojo SDI | 2x 23" ACD [view my complete system specs]
    "To achieve greatness only two things are required; a plan, and not quite enough time"
    Gustav Mahler
  • Mon, Oct 24 2011 3:34 PM In reply to
    Re: Alexa Workflow
    BlueGirl Media:
    No. The conversion with LUT will convert from 4x4 to Rec709.
  • Mon, Oct 24 2011 3:42 PM In reply to
    • BlueGirl Media
    • Posts 143
    • Points 1,960
    Re: Alexa Workflow
    Hi Job ter Burg,
    Thanks for the quick reply. Would RGB be correct if AMAing the ProRes 4444 directly?
    G.
    Gustav Mahler
  • Tue, Oct 25 2011 12:57 AM In reply to
    Re: Alexa Workflow
    BlueGirl Media:
    I'm curious how the DIT is applying the LUT. If Alexicc is being used, I have suggestions. It should be possible to provide MXF media at two resolutions with a LUT applied skiping the need for AMA.
    Alexicc is not cheap but pretty amazing.
    Robert
  • Tue, Oct 25 2011 2:10 AM In reply to
    • MichaelP
    • Boston
    • Posts 2,444
    • Points 30,585
      Avid Employee
      Moderator: Film
      Moderator: MetaFuze
    Re: Alexa Workflow
    Do the QT filenames match the clip names in the ALE? What are they using to create the files? Silverstack Pomfort? AlexiCC? DaVinci Resolve? I use Resolve to make native MXF dailies when needing to apply a LUT (be it Alexa or Canon 5D with Cinestyle LUT). But you need to purchase the MXF option to make native DNxHD ($495 from B&H).
    DNxHD 36 is a REC 709 8 bit codec, so no need for RGB.
    Does the ALE into which you are importing have filename in the TAPE field? Is it the full filename and not the truncated 8 character set? You can't relink (conform) between TAPE and SOURCE FILE (AMA or direct import) until the next version of MC.
    Michael
    24p.com
