Latest post Wed, Sep 28 2011 9:38 AM by tonyjover. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Sep 20 2011 12:02 AM
    • vudoo
    • Joined on Sun, Nov 21 2010
    • Posts 97
    • Points 1,505
    Will this Hp Z800 work with Avid DS
    I'm looking to buy a new computer to use with Media composer and Avid DS.  I can't seem to find the approved model listed on the Avid site so i was wondering if this unit will do:
    HP Z800 Workstation
    Intel Xeon six core E5649 (2,53 Ghz, 12MB Cache, 1333 Mhz memory)
    Win 7 pro
    6 GB ram
    Nvidia Quadro 4000
    Obviously, this is not a dual 6 core but is there a big performance difference between 6 or 12 cores ?? Thanks
  • Tue, Sep 20 2011 12:57 AM In reply to
    Re: Will this Hp Z800 work with Avid DS
    Yes.
    "Generic"
    MC 2022, W10, MSI X299M, Intel 9940X, Gigabyte 3080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Big... [view my complete system specs]
  • Tue, Sep 20 2011 1:29 AM In reply to
    • vudoo
    • Posts 97
    • Points 1,505
    what would you recommend:
    1- 6 core @ 2.53 for $3800
    or
    2- 12 core @ 2.66 for $4800
    Obviously the second choice has more core but i'm not sure if DS can actually take advantage of it or i'm i just waisting money.  Thanks
  • Tue, Sep 20 2011 1:48 AM In reply to
    Actually, DS is very well threaded.
  • Tue, Sep 20 2011 1:59 AM In reply to
    • vudoo
    • Posts 97
    • Points 1,505
    meaning it can use all 12 cores without any problems ???
  • Tue, Sep 20 2011 1:45 PM In reply to
    • slabross
    • Montreal, Quebec, Canada
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    vudoo:
    But this would be at your own risk.  Engineering made some adjustments for the 6-core processor, and it is possible that 12-core might require additional tweaks, so I would advise against such a purchase without proper testing and qualification from Avid.
    Sylvain Labrosse
    Principal Expert | Services and Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    Create cases online now at  csportal.avid.com
    It's fast, easy and effective!
    We're Avid.  Learn more at www.avid.com
  • Tue, Sep 20 2011 2:27 PM In reply to
    • vudoo
    • Posts 97
    • Points 1,505
    Sylvain,
    Now i'm confused, the system requirement states that DUAL hex core (12 cores) is approved, are you saying that a SINGLE hex core will yield better performance ??? Thank
  • Tue, Sep 20 2011 5:15 PM In reply to
    • slabross
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    If you meant a total of 12 cores spread across two 6-core processors, then yes this is qualified and supported.  Wink
    Some people are enabling hyper-threading and it displays as 24-cores in Windows.  THAT is not supported.
    Sylvain Labrosse
    Avid
    Canada
  • Wed, Sep 28 2011 9:38 AM In reply to
    • tonyjover
    • Birmingham UK
    • Posts 397
    • Points 4,735
    • Moderator: Avid DS
    vudoo:
    6 GB ram
    Note that this is the absolute minimum. I wouldn't scrimp on RAM for a DS installation and would personally treat 12GB as the least I would go with.
    Regards,
    Tony
