Latest post Fri, Sep 2 2011 8:00 PM by dcfilm. 4 replies.
  • Fri, Sep 2 2011 6:18 PM
    • dcfilm
    • Joined on Fri, Sep 2 2011
    • Posts 5
    • Points 65
    Audio stops playing from sequence in timeline
    So,
    I just loaded MC 5.5.2 onto a mac system and have had this problem a few times in the last couple of days.  Audio stops playing on a sequence when in the timeline.  I can load a clip into the source monitor and get audio to play out and I've loaded other sequences and they play but I've had a sequence stop playing audio (no levels as well) depsite checking it with wave form on and seeing audio.  It doesn't seem to be a system preferences issue since I can still get audio to play and I can't find any settings that would suddenly disable audio in a sequence.
    I've deleted site settings to see if that would fix it but that didn't work.  The only way I've found to get it to play audio again is to cut it into a new sequence or paste into a new bin.  Is this a bug with MC 5.5 or has anyone else had this issue?
    MAC PRO OSX 10.6.8 2 X 2.24 Quad Core Intel Xeon 16 GB 1066 DDDR3 RAM QT 10.0 [view my complete system specs]
  • Fri, Sep 2 2011 6:38 PM In reply to
    Re: Audio stops playing from sequence in timeline
    Please provide full system specs;  model of Mac, procs, RAM, OSX version,QT version, etc.  If you add this info to your profile, then it'll be a permanent record.
    Just in case, 5.5.2 is not supported with Lion.  You'd need 5.5.3 ....
    (wwld)
  • Fri, Sep 2 2011 7:11 PM In reply to
    • dcfilm
    • Posts 5
    • Points 65
    MAC PRO Tower
    MAC OSX - 10.6.8
    2 X 2.24 GHZ Quad Core Intel Xeon
    QT 10.0
    Adding to permanent record now also.  Let me know if you need anything else to trouble shoot.
  • Fri, Sep 2 2011 7:26 PM In reply to
    MC 5.5.2 isn't supported with OS 10.6.8, either.  I'd suggest going to 5.5.3 first before more troubleshooting.
  • Fri, Sep 2 2011 8:00 PM In reply to
    • dcfilm
    • Posts 5
    • Points 65
    Thanks!  I'll do the upgrade and see if it returns.
